Solitaire wrote:The rear lights will leak water into the tyre well
So THATS how! I have a puddle, but oddly, not one little bit of rust? Hmm. I'm just going to drill a couple of little holes in the wheel well, and spray it.
Solitaire wrote:heaps of fun to drive and get about 550k's from 40litres
Its' awesome! I've owned all manner of FWDs, turbos, vtecs, and none have come close to the amount of fun I'm having with this one! Such a nicely balanced, chuckable chassis, very predictable, and outstanding turn-in.. could do with a little more power out of corners, but I'm working on it! Looks like blacktop extractors, pod filter setup, and a decent tune will be the extent of my mods for the time being, I'm looking around for a decent set of good bang-for-buck lowered coils too, if anyone has any recommendations?
jondee86 wrote:But you could probably get away
without it if you just set your idle speed 100 rpm higher.
Yeah, I'm going to try and do without it. The only other issue I'm having with the car, is the knocking from the front shocks when TEMS is set to "hard", I assume I can attribute this to a loose shock insert retaining nut? I haven't had much chance to get under it in this weather, lol!
Overall, I really am impressed! I should've bought a 4AGE-powered something a long time ago!
