4age diagnosis code 52
Postby slighty_looney » Sat Aug 05, 2006 2:43 pm
driving my car today when the engine check light came on, found out it was code 52 (thanks to sykotic) its knoc sensor #1, i switched the car off and took it for a drive just b4, the lights not on anymore and the car seems to be driving fine, what should i do?? should i replace the knock senser or just leave it because im not keeping this engine for long anyway>?
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby Mr Revhead » Sat Aug 05, 2006 3:15 pm
check for loose wires/dodgy plug
Postby gepsk8 » Sun Aug 06, 2006 7:56 pm
do as revhead says, wouldn't nana until u sus it. as if ur ecu doesn't retard ur timig if its knocking something will blow.
i've got two silver top knock sensors if it is the problem?
gepsk8
