Take it the head has been machined and crack tested?ants_ae92 wrote: My ongoing problems with my 4age continue.
Blown headgasket - replaced
Blocked radiator - because of the blown radiator (flushed and cleaned)
If the system is still pressurising theres a good chance you still have combustion gases in the cooling system, get a tk or cyl leakage test done then go from there or you will be walking around in circles....ants_ae92 wrote: had/have a pressurised cooling system, which we thought the flushed radiator would have fixed.
No the head had no signs of warpage at all, so we left it.
looks like I might just take it off the road, as I was going to do a turbo conversion with a small port motor/gze pistons. So I think I will just go the whole hog and do it properly with that motor. I dont want to have to spend money on a motor im just going to pull out and sit in the garage.
Thanks for your help man.
deaf_rattle wrote:
i didnt realise warping was visible
It isnt.
do it once do it right.
It isnt.
yes i realise that
and yes, do it once and do it right
It isnt.
yes i realise that![]()
