Small port getting busy... Problem sorted :))
Postby jondee86 » Sun Aug 13, 2006 1:45 pm
I've noticed that the small port gets very busy over 6000 rpm !! By this
I mean top end noise... cam on buckets I would guess. The engine is bog
stock, and runs fine. Winding it up, its just exhaust growl up to 6000 and
them a big rush of noise... like hail on a tin roof :)
Could some of you small port pilots tell me if this is normal for a small
port ?? I can't say I ever noticed the same thing happening on my big
port engines until I was pretty much red lined, and even then it wasn't
anywhere near as loud.
Cheers.... jondee86
Watch this space >>> <<<
jondee86
Postby jondee86 » Sun Aug 13, 2006 10:11 pm
Kind of hard to believe that no-one ever redlined a small port :roll:
Cheers... jondee86
jondee86
Postby gepsk8 » Sun Aug 13, 2006 10:58 pm
nah, don't think mine does but if ur picked up on a sound ur always gona hear it, as ur tuned into the sound.
can take for a drive in mine if u wanted?
gepsk8
Postby blackie » Sun Aug 13, 2006 11:35 pm
dont recall my brothers/mates smallport 4ages making such noises ...
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1892
When my bros call.. dey get hit wit da chinnggggaayyy
blackie
Postby RS13 » Sun Aug 13, 2006 11:56 pm
Mine doesn't make that noise, just a constant "scream" to redline.
RS13
Postby AE85coupe » Mon Aug 14, 2006 9:39 am
mine has huge amounts of intake noise from about 5000 or so onwards, but not a hail on tin roof noise haha
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby gordon77 » Mon Aug 14, 2006 12:17 pm
yeah mine just screamed all the way to red line too 8) no funni noises, just smallport goodness :)
What is RR?
gordon77
Postby pc » Mon Aug 14, 2006 12:35 pm
detonating?
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Cahuna » Mon Aug 14, 2006 12:40 pm
The smallport in my Corolla is fine, no strange noises when reving (a couple of unidentified ones when idling though).
Could it be a loose bolt somewhere? The Sentra had a strange rattle at high revs that sounded like it was about to drop its guts, turned out that the bolt holding the alternator on had worked its way out and was causing a vibration at those specific revs. Tightened the bolt and it was all good again.
We know that four-wheel drive doesn't work in a racing car, and I proved to myself that it doesn't work very well for rallycross. I'm absolutely convinced that it has no future in rallying, either, even if the regulations allowed it. - Roger Clark (rallying legend), circa 1976
Cahuna
Postby solitaire » Mon Aug 14, 2006 2:10 pm
Mine screams to the point where you cant hear yourself think... so i wouldnt know...
Having said that mine makes a tapping noise untill the oil has covered everything when cold... and i can only hear that when in front of it...
AE92, KZJ120, KDJ120
solitaire
Annoying noises....
Postby jondee86 » Mon Aug 14, 2006 10:19 pm
Thanks for the comments. I think I'll just live with it for the time being.
Possibly the valve clearances have opened up a bit, and I might have to
do the shims when I drop my new cams in 8)
Cheers.... jondee86
jondee86
Talking of weird shit !!!!!!
Postby jondee86 » Sun Mar 18, 2007 9:47 pm
Well I finally discovered what was causing this noise. The hydraulic
line (steel tube) from the clutch master to the clutch slave has no
clips or brackets... it just runs clear of the bodywork and is held at
the ends. It twangs like a guitar string when you tap it, and it clears
the bulkhead by at least a fingers width.
However, the tube has a resonant frequency at 6000 engine rpm, and
gets the major vibration going... enough to cause it to thrash itself
against the firewall like a beserk vibrator !!! This gave rise to the "hail
on a tin roof" sound you could hear inside the car.
Weirdest thing I ever came across, but a couple of bits of rubber fuel
line slit and slipped over the hydraulic line solved the problem. I got
my redline back, and it sounds sweet :)
Cheers... jondee86
Oh, it would have been nice to have discovered this before I invested
in a new clutch, pressure plate and throwout bearing :oops: But hey...
now I know that everything is in top condition :D
jondee86
Postby frost » Mon Mar 19, 2007 10:26 pm
good to hear your engine is all sweet.
on a side note those AGX look really good. are they for your 86? can u give tell me any specs on those shocks?
AGX Shocks...
Postby jondee86 » Mon Mar 19, 2007 10:47 pm
Yup... will be going in once I get a set of front strut casings chopped
40 mm and some spacers made up :D They are the classic SW20
front inserts (4-way adjustable) and Camaro rears (8-way) combination
recommended by Gabe Tyler from T3.
I have the part numbers and dimensions if you want them.
Cheers... jondee86
jondee86
Postby frost » Mon Mar 19, 2007 11:18 pm
oic. i was going to get the ae92 fronts and camaro rear's. was there a reason gage said the sw20's instead of the ae92?
im thinking of using ae92's because i don't know the full extended length of the sw20 shocks. the ae92's are like this.(thanks GD)
Body length: 336mm
Extended length: 500mm
Extended minus Body: 164mm.
thats the closest i could find to tokiko hts s/s at half the price.
if you can do the same measurements on the sw20's for me that would be great. and the part numbers please :D
AGX Shocks...
Postby jondee86 » Tue Mar 20, 2007 8:29 pm
Oops.... oh well, might as well use this box since I can't delete it :?
AE92 inserts have about the same cartridge length, but the extended
length and stroke are shorter than the SW20.
HTS102 inserts have :
Lmax = 476 mm
Lmin = 350 mm
Cartridge Length = 332 mm
Stroke = 126 mm
Nice shocks for a track car, but getting kind of short in travel for a
road car that has to deal with typical suburban NZ streets.
Cheers... jondee86
jondee86
AGX Shocks...
Postby jondee86 » Tue Mar 20, 2007 8:30 pm
For measuring and comparing inserts, you need these dimensions :
I chose the SW20 front inserts (KYB Part# 765 015), and I have
measured these myself as follows :
Lmax = 517 mm
Lmin = 354 mm
Cartridge Length = 338 mm
Stroke = 163 mm
The threaded end of the rod is inside the top hat and plays no part in
suspension travel calculations. Also remember that the rod does not
retract fully into the body.
With the springs I have at the moment, I have about 32 mm of travel
on the compression stroke before the OEM bumpstop bottoms out.
With the new inserts I will have around 68 mm of compression travel,
and maybe 60 mm of extension travel. Thats around the minimum
required for a road/Targa car.
Race cars... the stiffer the better, as the actress said to the Bishop :D
Cheers... jondee86
jondee86
Postby frost » Wed Mar 21, 2007 4:01 pm
thanks for the info. i'll get the same set up as you got next week.
