Aftermarket Cams
Aftermarket Cams
Postby Adydas » Sun Aug 20, 2006 11:48 pm
Ok guys, i made my choice on brand of cam but i noticed 2 options, can anyone help shed some light on these to help eliminate or figure out what the best choice for my application is?
Gen 3 3s
Ball parking 220kw
Here are my options ( for just ex i assume same choice is made for in )
264 with 9.7mm Lift
264 with 8.75mm Lift
HKS - Camshaft Toyota
Toyota 3S-GTE, EXHAUST, 264 degree, 9.7mm lift, (For Inner Shim) This product cannot be installed on VVT-i camshaft side. Cylinder head needs to be modified to install this camshaft
Toyota 3S-GTE, EXHAUST, 256 degree, 8.75mm lift, This product cannot be installed on VVT-i camshaft side. Cylinder head needs to be modified to install this camshaft
Adydas
Postby fivebob » Mon Aug 21, 2006 4:52 am
http://www.cj-motorsports.com/camtest.htm
Only has the low lift 264's, but I would expect the same results as the difference between the low and high lift 272's
Postby Adydas » Mon Aug 21, 2006 9:35 am
You are my hero.
Adydas
