Cleaning out sunroof drains
Postby ATAl » Sun Aug 27, 2006 12:41 am
Evening all
Does anyone know where the sunroof drains in an ae92 levin come out?
I apparently need to blow compressed air backwards thru them to stop my roof leaking.
Also is there just the two drains at the front, or are there more hiding at the back?
ATAl
4 drains
Postby andyztouring » Sun Aug 27, 2006 10:16 am
there are 4 drains,2 at the front of the sunroof tray,2 at the back,usually come out either on top of the rear wheel arch or behind the wheel arch,it is easy to drop the headliner,take the drain hoses off the sunroof tray, and blow air or water thru them(you cant get at the rear drain tubes with headliner in place if I remember right).Cheers
andyztouring
