Wiring up speed sensor
Postby postfach » Mon Aug 28, 2006 7:31 pm
I'm trying to wire up the speed sensor for my car, but i can't figure out which wires go where. There are 3 wires on the speed sensor, red, green, and light blue. I assume 2 of these wires will be +12v and gnd and the other will be the spd signal, but where do i wire the spd signal to? The car is an MZ20 soarer with digi dash, and the engine is a 1JZ-GTE out of a JZX90
postfach
Postby Jason T » Mon Aug 28, 2006 7:55 pm
Fixing Toyota's since '87
Jason T
Postby postfach » Mon Aug 28, 2006 9:07 pm
thanks, for some reason im unable to visit 1jz-gte.us at the moment (usually works, but occasionally it just wont work??) but ill have another look there when it lets me :P
postfach
Postby sergei » Tue Aug 29, 2006 1:33 am
Speed sensors usualy go to dash, than from there it is "converted" to a signal which is read by ECU.
