I scored a free 4 wire oxygen sensor from a silvertop 4age, will it work fine on my 4agze? It is supposed to have a 4 wire, but is currently fitted with a single wire unit.
the four wire has the heater, and a seperate earth wire to the ecu for less interferance, if u ecu runs a 4wire stock u should have no problem using it
SUBARUCONVERT wrote:the four wire has the heater, and a seperate earth wire to the ecu for less interferance, if u ecu runs a 4wire stock u should have no problem using it
