Brake Ducts on AE86, anyone done this ?
Postby beeker » Tue Sep 12, 2006 6:55 pm
How did you route the ducting to get it close to the rotor centre, but avoiding the wheel hitting on full lock ?
Got pics ?
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Rick » Tue Sep 12, 2006 8:30 pm
Postby beeker » Tue Sep 12, 2006 8:38 pm
Rick wrote:Image
Thats an E30 M3. I'm struggling with the best path for the AE86 without it getting to be the lowest hanging part on the car.
06 RS4 Avant
beeker
Postby wde_bdy » Tue Sep 12, 2006 8:52 pm
Thought about coming down the strut from above?
Callum
wde_bdy
Postby beeker » Tue Sep 12, 2006 8:57 pm
wde_bdy wrote:Thought about coming down the strut from above?
Callum
But that means cutting a hole in the inner steel guard. I have considered this, but I would be concerned if this affects the structural strength of the wheel well.
06 RS4 Avant
beeker
Postby wde_bdy » Tue Sep 12, 2006 9:06 pm
Nah, just run from the front along the side of the inner guard up high to the spring seat area and then down from there. you just need enough slack to allow for the spring movement and a bit of turning. Should be easy to keep it well clear of the wheel.
Callum
wde_bdy
Postby beeker » Tue Sep 12, 2006 9:09 pm
wde_bdy wrote:Nah, just run from the front along the side of the inner guard up high to the spring seat area and then down from there. you just need enough slack to allow for the spring movement and a bit of turning. Should be easy to keep it well clear of the wheel.
Callum
I'll take a look, but from memory the 205/15" wheel on lowered suspension gets pretty close in there.
06 RS4 Avant
beeker
Postby wde_bdy » Tue Sep 12, 2006 9:17 pm
What offset you running? I've got 15 x 6.5's in P20 offset with 205/50's on my KE70, not running ducting yet but from what I looked at there was definitely room to get through there. What diameter ducting have you got?
Callum
wde_bdy
Postby beeker » Tue Sep 12, 2006 9:32 pm
wde_bdy wrote:What offset you running? I've got 15 x 6.5's in P20 offset with 205/50's on my KE70, not running ducting yet but from what I looked at there was definitely room to get through there. What diameter ducting have you got?
Callum
Its 3" 600C high temp brake ducting. Running 15x7" wheels, offset errr 8 or 15 (cant remember).
I've just checked, and on full lock the tyre touches the ducting when trying to duct accross the top and then down the strut, even without any further compression caused from bumps or hard turns. So that plan wont work.
I assume the AE86 is different from the KE70. Any other ideas ? Surley some AE86 owners must have done thus ??
06 RS4 Avant
beeker
Postby Dell'Orto » Tue Sep 12, 2006 9:39 pm
They arent that different really, they are both Corollas after all.
Could you maybe run ducts from the centre of the front lip, and aim them at the back of the rotors?
Postby beeker » Tue Sep 12, 2006 9:48 pm
Mmm, Boost wrote:They arent that different really, they are both Corollas after all.
I can get the ducts to just short of the front of the tyre, but thats not really effective. Probably better than nothing, but ideally you get the air feed right up to the rotor itself. Some even create a custom rotor covers as above on the E30 M3 example and feed the air right into the rotor itself.
Anyone else put ducts into an AE86 ???
06 RS4 Avant
beeker
Postby 85AW20v » Tue Sep 12, 2006 10:03 pm
I'm pretty sure that Fred from Hamilton doesn't run any ducting on his Targa AE86 - the yellow one - and with 185hp at the wheels if he needed it he would have it. He runs four pot Wilwoods all round but I'm not sure on the pads. I'll find out and let you know.
See ya
Simon
85 MR2 20v
85AW20v
Postby beeker » Tue Sep 12, 2006 10:13 pm
Simon85MR220v wrote:I'm pretty sure that Fred from Hamilton doesn't run any ducting on his Targa AE86 - the yellow one - and with 185hp at the wheels if he needed it he would have it. He runs four pot Wilwoods all round but I'm not sure on the pads. I'll find out and let you know.
Yeah, fred has a nice car. Obviously when you run a thicker and larger rotors ducting isnt so important. As im still running std ae86 brakes so I tend to get small bomb fires at the end of long stages!
Do you have freds email ? or ph ? I've been meaning to ask him another question.
06 RS4 Avant
beeker
Postby nzae86 » Wed Sep 13, 2006 7:22 pm
Hi there
Fred's work number is 07 8505240
Sorry I haven't got back to you on the axles as i have been away , i do have some spares for my rally car but I did fit brand new one's when I rebuilt my car, but I dont want to part with them, try grant as I'm not sure if he sold off eveything with his 20v ae86.
i run bigger rotors on the front of mine (same size as evo 1-3) and never have a problem with it stopping.Try fitting some pagid pads as we use these in all types of rallying and are one of the best pads for ae86's to capris, to evos,but rotor size and pad area is where it's at
Steve W
Your addiction to motorsport can only be cured by poverty!
nzae86
Postby beeker » Wed Sep 13, 2006 9:34 pm
nzae86 wrote:Hi there
Steve W
thx Steve.
06 RS4 Avant
beeker
Postby beeker » Thu Sep 14, 2006 10:13 pm
Spoke to Fred today, and they have just got 195WHP out of his NA 4age. Not too bad if you askme.
06 RS4 Avant
beeker
Postby 85AW20v » Sat Sep 16, 2006 12:07 am
The 195whp would be out of what he calls his "good" motor. The 185whp is out of his spare!! We ran the spare one for 4 days of Targa last year after losing the good one at Inglewood after the last stage on the Tuesday but he's done a bit to it since then.
See ya
Simon
85 MR2 20v
85AW20v
Postby beeker » Sat Sep 23, 2006 2:17 pm
Ended up doing this:
Couldnt get the outlets any closer without rubbing on the wheel, or risking affecting the steering. Ideally you would cut a hole in the engine bay wall and come straight to the hub, however I didnt want to risk that one.
06 RS4 Avant
beeker
Postby RS13 » Sat Sep 23, 2006 3:00 pm
Probably not too relevant, but on the ae92, the ducting for the brakes is built into the rear of the backing plate, like this:
It sticks out from the inside of the wheel, directing airflow onto the rotor through those vents. Perhaps fabricating a diffuser like that for your car may be more effective than the hose? I'd imagine the flow of air coming from the hose to the brakes would be almost non-existant with such a cross-draught.
RS13
Postby beeker » Sat Sep 23, 2006 4:30 pm
RS13 wrote:Probably not too relevant, but on the ae92, the ducting for the brakes is built into the rear of the backing plate, like this:
Interesting idea. Perhaps for a rainy day.
The photo's I have posted looks like there is a large gap, but in reality its less. It was directly copied from another AE86 Targa car, and quoted as making a difference, so fingers crossed. They previously didnt need them, but like myself once the bib spolier got installed, the brakes needs additional air.
06 RS4 Avant
beeker
