setting cams/shims on 4age big port head
Postby Pies » Mon Sep 18, 2006 10:42 pm
so ive come to the point in my build where i havent ventured before. aftermarket cams (que DUN DUN DUN music)
how do i got about setting the shims to the right height?
so far i have pulled the head off the old block. EVERYTHING is being replaced. i have new valves, new headset, new cams, new head bolts, new anything else i could think of.
what will i need to do to the head to prep it? it is going off to headmasters soon to get a bit planed off the raise the compression, is there anything else besides pressure testing i should do?
thanks for any input. please, no bullshit or i'll punch you in the dick
Current Rides:
Pies
Postby 4age_rage » Mon Sep 18, 2006 10:44 pm
if your handy with a dye grinder maybe polish up the ports a bit i wouldnt go making them any bigger though
4age_rage
Postby 4age_rage » Mon Sep 18, 2006 10:45 pm
4age_rage
Postby Pies » Mon Sep 18, 2006 10:47 pm
that thought had crossed my mind. will probably end up doing it, unless somoene offers to do it for me when im getting all the other headowkr i cant do, done.
Current Rides:
Pies
Postby 85AW20v » Mon Sep 18, 2006 10:49 pm
You can go to underbucket shims using Echo buckets - they drop straight in but if you're not doing high revs, it probably doesn't matter.
See ya
Simon
85 MR2 20v
85AW20v
Postby Pies » Mon Sep 18, 2006 10:51 pm
yes ive heard about that one. do you have a link to the website that explains how its done? i know there is one, just cant remember which one lol
Current Rides:
Pies
Postby 85AW20v » Mon Sep 18, 2006 11:04 pm
Haven't done it myself but the AE86 I was co-driving in at Targa last year has done it to both his motors and we're pulling 8500-9000rpm all day. He's also getting 195 and 185RWP out his good motor and his spare so something must be right!! Don't know about the website.
See ya
Simon
85 MR2 20v
85AW20v
Postby Pies » Mon Sep 18, 2006 11:06 pm
well if anyone knows of the link, feel free to post it :)
now how do i go about setting shims?
Current Rides:
Pies
Postby Mr Revhead » Mon Sep 18, 2006 11:31 pm
shiims? i wonder.....
those shim under buckets are not the nz echo, but imports with the 1sz engine
iv been meaning to sort out some decent pricing for them
Postby matt dunn » Mon Sep 18, 2006 11:36 pm
Measure the valve clearance, work out how far out it is,
take out the shim and measure it, and work out what size shim you need and go and buy it.
Repeat another 15 times.
Matt
Postby Mr Revhead » Mon Sep 18, 2006 11:45 pm
yeah told u that last week pie man!! :P
Re: setting cams/shims on 4age big port head
Postby cosi » Tue Sep 19, 2006 1:42 am
Pressure test the head before you do anything else. There wouldnt be much point porting it unless you have a flow bench, clean up the casting marks on the intake runners if there are any. Make sure the combustion chambers are the same volume. Have someone cut the valve seats on a serdi, apparently 3 angle seats improve the flow of air into the chambers. Match the intake manifold to the head. Have the head decked/planed last. Maybe get some decent valve seats. Not sure what you can do about the valve guides on a 4age
cosi
Postby RedMist » Tue Sep 19, 2006 8:33 am
cosi wrote:Pressure test the head before you do anything else. There wouldnt be much point porting it unless you have a flow bench, clean up the casting marks on the intake runners if there are any. Make sure the combustion chambers are the same volume. Have someone cut the valve seats on a serdi, apparently 3 angle seats improve the flow of air into the chambers. Match the intake manifold to the head. Have the head decked/planed last. Maybe get some decent valve seats. Not sure what you can do about the valve guides on a 4age
This is good advise for a basic build. Don't go anywhere near polishing, you loose boundary layer effect which slows velocity, decreases your charge, and hence HP. Polishing ports is very old school. The verdict is out in regards to polishing the combustion chamber.
Valve guides on inlet can be cut back. However this will reduce the life of the guide dramatically. I wouldnt cut back exhaust valve guides, they remove heat from the valve.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Pies » Tue Sep 19, 2006 12:17 pm
last 2 answers are fuken great. thanks guys :D
Matt: thanks... i didnt fully understand what warwick was telling me last time cos i was stuffing my face with pizza :P
Current Rides:
Pies
Postby crnkin » Tue Sep 19, 2006 5:17 pm
pies.
i must suggest if your getting cams, to get it reshimmed. And when you get it re shimmed, get a professional to do it. If theres one thing that will make you annoyed with a rebuilt engine, it will be the fact you saved 200 bucks and it ticks like a mofo.
I got quoted 750 for a full rebuild head with complete port job. Probly be worth it. If everything else is being done
deaf_homo "currrently yes"
crnkin
Postby CAMB01 » Tue Sep 19, 2006 7:28 pm
Probably not a good idea to stick with the 4age shim and bucket as when i had my aftermarket cams in it rattled really badly, sounded like all 16 tappets were loose (i had rebuilt the head and set the tappets accurately as they were checked many times cause i thought they were loose).
The shim was rocking on the bucket, but still revved to 8000rpm no problems for about 10000km's then decided to pull them out as i got sick of the sound.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby RedMist » Tue Sep 19, 2006 8:11 pm
CAMB01 wrote:Probably not a good idea to stick with the 4age shim and bucket as when i had my aftermarket cams in it rattled really badly, sounded like all 16 tappets were loose (i had rebuilt the head and set the tappets accurately as they were checked many times cause i thought they were loose).
I race against a 4age built by Kelfords with very similar lift and duration to my shim under bucket solution. His standard bucket engine doesnt sound any different to mine, runs as smooth as mine on idle, in fact its hard to tell the engines apart (other than mine produces 2.5bhp more!)
And we are talking about 304 degree 415 thou lift cams. ( I think, although can't confirm as he wont give me details, his lift is slightly less) are you sure you didn't insert one of the shims upside down? They are convex.
In regards to the Toyota shim under bucket,
http://www.club4ag.com/faq%20and%20tech ... uning.html
RedMist
Postby CAMB01 » Tue Sep 19, 2006 11:02 pm
RedMist wrote:I race against a 4age built by Kelfords with very similar lift and duration to my shim under bucket solution. His standard bucket engine doesnt sound any different to mine, runs as smooth as mine on idle, in fact its hard to tell the engines apart (other than mine produces 2.5bhp more!)
The shims were installed the correct way up, but it definitely sounded like it was all 16.
Everything was checked multiple times, clearances were fine and shims were correct way up.
When i had the head on the bench after i pulled it out the car, slowly turning the cam i could see the shim rocking on the bucket, not a lot of movement but enough to cause a sound at high speeds like 1200rpm
CAMB01
Postby Bazda » Tue Sep 19, 2006 11:09 pm
maybe cos ur thing is friken loud so u can hardly notice it, but on a road car the exhaust is really quiet so u hear any little noise.
my pistons rattle bad with my silencer in, i take it out and its like 70% better :D
Postby Pies » Tue Sep 19, 2006 11:22 pm
thanks for the link redmist. so, am i correct in assuming all i have to do is buy the 1sz shims and swap them straight in? nothing else? (apart from getting the right ones of course
Current Rides:
Pies
