4agze 8.9 or 8.0 comp?
Postby Donor » Thu Oct 05, 2006 1:33 pm
Hi fellas,
had a search and couldnt find what I was after.
Im looking at buying a 4agze but the owner doesnt know if its a hi compression ae101 or a low compression one?
can anybody tell me if there is anyway of identifying which one it is? cause my motor has been cooked and I need a hi compression one. ae101 gtz levin thankyou
Donor
Postby IH8TEC » Thu Oct 05, 2006 1:38 pm
is it just the engine? or is it in the car. there is heaps of stuff on this subject on toyspeed.
low comp ones have an afm, look in my profile and you'll see a big box thin before the t/b.
Postby crnkin » Thu Oct 05, 2006 2:51 pm
look at the size of the ports. smallport indicates high compresion.
The easy way to tell is look at the gaps in between the ports. If the gaps in between are larger than the ports themselves, its smallport high comp. If the gaps are smaller than the ports, its low comp bigport
deaf_homo "currrently yes"
crnkin
Postby Donor » Thu Oct 05, 2006 6:25 pm
crnkin wrote:look at the size of the ports. smallport indicates high compresion.
thanks thats good advice crnkin, the motor is out of the car with no duct on the intake, and is a complete motor, i dont think the guy wants to take off manifold and that to check, is ther any other way you can tell???by looking at the intake and that or??he said he brought it from the wreckers and didnt ask which one!!. whats a fair price for one he wants 1300 bucks,thanks for your time!!!!
Donor
Postby crnkin » Thu Oct 05, 2006 8:00 pm
you can tell with the manifold still on
crnkin
Postby matt dunn » Thu Oct 05, 2006 8:32 pm
Best and easiest way to tell is to look fot the external oil drian from the head down into the block.
At the back, on the intake side.
If it's there it's a smallport high comp one.
Matt
Postby Bling » Thu Oct 05, 2006 9:11 pm
take a photo, post it here (if ya can) and you'll have people falling over each other to tell you what it is :lol:
good ol' toyspeeders :P
Postby Donor » Fri Oct 06, 2006 12:24 pm
awesome, thanks matt dunn, it does have a drain at the back so its the one im after,cool,btw thanks ih8tec,crankin,bzbling for your help also it is much appreciated,toyspeed rocks!cheers guys!!!!!!!!!!!!!!....
Donor
