Suspension Issues - NEED HELP!
Postby LEVIN GTV » Thu Oct 05, 2006 11:09 pm
Well hello again all,
Im going to need a huge effort from the toyspped community for this one...
SYMPTOMS
Basically my car is still suffering a few teething suspension problems. The symptoms are rattling, and clunking in the front suspension area : wheel, swaybar, etc...
As I drive straight there are no sounds, unless I hit a bump then there is a wobble, a rattle and a clunk...Turning corners the issues arise, when more tension is put on the steering.
Diagnosis
No 1:
CV Joints
These were replaced after the first mechanic tried and diagnosed the problem....However the inner joint was only reconditioned and not new. Could this be causing the problem?
No.2
Shocks
These were replaced today...
Other possibles:
Lower control arm bushes
These were also replaced today
Every bolt in the suspension has been tightened!
After all these the car is still suffering the initial problems. Although the new bushes were put in, along with the struts the car is much stiffer and firmer. The control arm bushes were difficult, but they do assist alot.
What could it be?
Im thinking sway bar...It is slightly touching the exhaust. However, they have been there together for about 1 year now...and the problems have only arisen recently (past 2 months).
The bushes are all in great condition, and the sway bar is all good and nice and tight...But it is clunking around a bit. Alot of people running whiteline swaybars have had similar issues.
But im disillusioned...After going to 3 separate mechanics and dealing with all those problems...The same issues still occur.
What should I look at?
Any ideas, help would be greatly appreciated guys!
LEVIN GTV
Postby bluemaumau » Thu Oct 05, 2006 11:12 pm
perhaps you aint lookin at the right thing, maybe its your exhaust thats loose, and clunkin around :?
Postby LEVIN GTV » Thu Oct 05, 2006 11:14 pm
bluemaumau wrote:perhaps you aint lookin at the right thing, maybe its your exhaust thats loose, and clunkin around :?
But the sounds are coming from the front right, and front left!
LEVIN GTV
Postby bluemaumau » Thu Oct 05, 2006 11:16 pm
o ok ignore
Postby 4age_rage » Fri Oct 06, 2006 1:23 am
bluemaumau wrote:o ok ignore
so what did you learn in primary school today
HC33 Laurel
AE92 Levin
ST185 GT-4 Celica
4age_rage
Postby thegreatestben » Fri Oct 06, 2006 5:27 am
Steering rack??
thegreatestben
Postby KinLoud » Fri Oct 06, 2006 8:15 am
A classic clunk maker is a worn swaybar link.
Check them as they do wear out.
Ken
Ham
021 408863
Postby trdfxgt » Sun Oct 08, 2006 3:25 pm
i read your post and i dont think you mentioned the top mounts or the spring capture plates do they all fit and capture well and are the top mount bushes ok
trdfxgt
