Water Spray on A/A intercooler st185
Postby FoRsaKeN » Fri Oct 06, 2006 12:33 am
Hey guys,
was just wandering...
Anyone ever thought (or tried) a water spray on top mount a/a IC.
I know the heat soak is pretty bad, and figured a quick spray on the IC before you go would mean the IC would cool faster once you start moving.... no??
I know the water itslf wouldn't cool much, but when moving, the water on the IC absorbing the heat would cool fast.
Well.. just random thought
thanks
'91 Celica GT4
FoRsaKeN
FoRsaKeN
Postby bluemaumau » Fri Oct 06, 2006 12:36 am
posted before, do a search, but i think main ptroblem is runoff into head
spray
Postby FoRsaKeN » Fri Oct 06, 2006 12:53 am
oh ok... couldn't find anything on it.
all i found was internal water sprayers, and water sprayers for w/a intercoolers... but thanks anyways
'91 Celica GT4
FoRsaKeN
FoRsaKeN
Postby Stealer Of Souls » Fri Oct 06, 2006 8:31 am
You're thinking about spraying water on the outside of the core right... If so not quite sure if run off in to the head would be a problem... But it could be...
I would try a fan first if possible. Put it on a speed triggered switch to run only when not moving (or not moving fast). That will help keep the heat soak to a minimum.
Water spray could be used to further improve things. Autospeed had a system that I thought looked really good. It was titled something like...
The worlds best intercooler water spray.
'86 AE85.5 Levin
Stealer Of Souls
Postby MrOizo » Fri Oct 06, 2006 10:37 am
i reckon a fan would be better first before a water sprayer.
With the water sprayer, you'll need something with enough pressure and nozzles small enough to get very tiny droplets - a mist kinda spray.
MrOizo
Toyspeed Legend
Postby Adydas » Fri Oct 06, 2006 10:39 am
not to meniotn somehwere to store it
Adydas
Postby Stealer Of Souls » Fri Oct 06, 2006 11:24 am
MrOizo wrote:i reckon a fan would be better first before a water sprayer.
The autospeed one will do that... but it'd be around about $200-$250 for all the kit.
Dirty old fan... $40?
'86 AE85.5 Levin
Stealer Of Souls
Postby Skin » Fri Oct 06, 2006 2:14 pm
Back when I had a st185 i made a rangi water sprayer up. Consisted of a 5l fuel container mounted in the boot,a window washer motor, a few metres of thin rubber hose and a bunch of water irrigation nozzles etc.
Worked well at first, but after some time the heat started screwing with the nozzles and they stopped misting, and just dribbled.
But while it was working it did actually help. I noticed the car had more response in traffic driving, and the car ran in "high" boost mode more often
cogent wrote:iPhones can eat a dick.
1981 Mazda RX7
1997 Toyota Corolla
Skin
Postby sergei » Fri Oct 06, 2006 2:46 pm
Best way is to get W/A or front mount (W/A is better)
w/a
Postby FoRsaKeN » Sun Oct 08, 2006 3:56 pm
Oh, so you reakon w/a IC is better than a front mount???
Guess w/a wouldn't give you the lag,etc
Thanks everyone
yea, a nice mist would be great...
was thinking of bleeding off water from the window washing system... just means tha everytime i want to use i, i have to wash my windows too :) lol
thanks
'91 Celica GT4
FoRsaKeN
FoRsaKeN
Postby Adydas » Sun Oct 08, 2006 4:35 pm
WTA for the win, Sergies onto it..
Adydas
Postby bluemaumau » Sun Oct 08, 2006 8:52 pm
w/a would be my choice also
Postby sergei » Sun Oct 08, 2006 10:20 pm
With my boost levels (~20-26psi, unfortenatly I cannot do anything about it at the moment) After a 30 min twisty bit country road test drive, while trying to figure out whats with the boost, straight after stoping at my mates place, I put my hand on i/c, while looking at the bloody waste gate actuator, the i/c was cold.
That is ST205 I/C with subaru I/C radiator, and 1 ST165 water pump + 1 Subaru water pump (same items) running constantly, and 30cm I/C radiator fan (either thermo switch or manual).
I doubt I would get that boost responce, temperature efficiency with a front mount, also I don't have space for it, without removing bumper beam ( 10cmx10cm ~3mm steel) and cutting lots of panels for piping to go through...
