Larger swaybars in FXGT
Postby crispy'86 » Sat Oct 07, 2006 8:21 pm
Went out to the track today for the sprint event and found my car's VERY understeery. Has anyone else noticed this same problem? I'm using standard front and rear swaybars for now to learn what the car does. Runnning new gabriel shocks and cobra springs, and standard road tyres. Now i want to sort out the problem one by one so has anyone noticed a huge difference with larger diameter front swaybar??? and similar setup?
crispy'86
Postby Bling » Sat Oct 07, 2006 9:35 pm
Not sure what your meaning exactly.... but bigger sway bar in rear reduces understeer afaik
Postby DexGT » Sat Oct 07, 2006 9:38 pm
If you want to make your car really understeer , then biger front bar is the way to go 8O , I would recomend a bigger rear bar , whiteline probablly make an adjustable one . I have one on my starlet and it makes the handling nice and neutral
DexGT
Postby AceSniper » Sat Oct 07, 2006 11:36 pm
if its the same ae101's take whiteline have a 18mm one thats adjustable 18, 20, 22mm helps alot with understeer
AceSniper
Postby DexGT » Sun Oct 08, 2006 12:15 am
heres the site you want for the parts avaliable
http://www.whiteline.com.au/
you will need to find the local dealer in christchurch then your set :wink:
DexGT
Postby Alex B » Sun Oct 08, 2006 12:21 am
Your local dealer would me Mr Revhead :wink:
Postby Leon » Sun Oct 08, 2006 8:49 am
Whiteline rear bar in my AE92 = instant oversteer on demand.
Postby 85AW20v » Sun Oct 08, 2006 8:56 am
You can also make the std one adjustable by welding tags along the top of it with holes drilled every 25-30mm. Easy to adjust and cost is way down on a Whiteline. See what is on the wrecks at the local dump too - the bar on the rear of my AW is off a Pelude of some sort.
See ya
Simon
85 MR2 20v
85AW20v
Postby Mr Revhead » Sun Oct 08, 2006 9:47 am
yeah whiteline do a couple for the ae82
Postby trdfxgt » Sun Oct 08, 2006 10:32 am
what is your set up ? eg camber etc my ae 82 has no understeer problems and its standed sway bars with ajustible suspension and race tyres
trdfxgt
Postby BigDon » Sun Oct 08, 2006 2:31 pm
These are the specs of the trd sway bars that were running in my ae101 fx and are now in my ae111 levin. Handling (empty no stereo etc car) is neutral tending to oversteer on the edge, its combined with trd adj coilovers. There is no body roll fanging it full noise around both the front and back tracks at manfield on race tyres,rims. Slap the stereo in the boot and it becomes and oversteering pig of a car,
Front 28.0mm, solid
Spring rate 57% up from standard
Rear 19.1mm, air
Spring rate 27% up from standard
www.europeandirect.co.nz
1996 AE111 BZ-G: TRD equipped road legal Club Car (Manfeild 1.25s) (SOLD)
1995 AE111 BZ-G: Stereo and daily driver (SOLD)
2005 NZ New Evo 9 GT (specd to FQ360) daily driver
2012 NZ New Outlander VRX - V6 family wagon
BigDon
Postby crispy'86 » Mon Oct 09, 2006 12:27 pm
Leon, what rear bar diameter are you using?
My setup is strictly low , low budget till i get used to what the car can and can't do, there's no way i want to splash out getting adjustable suspension and race tyres if my driving is mediocre, setup is just gabriel shocks new 1 month ago, cobra springs all round, I must admit i have yet to get a proper alignment and get the camber setup evenly as i just bolted the suspension in andadjust toe by eye. Yes, it is a bit rough but for a start i have to get used to what the car's bad traits are. Already had 2 off's at ruapuna. one understeer off the track at the hairpin and the other at 90 km/h entering the esses. Oh and i have seen the results of running race tyres when there's a beginner driver in the car. Race slicks + Adjustable suspension + beginner = Huge lose in the esses and rollover.
crispy'86
Postby Leon » Mon Oct 09, 2006 12:29 pm
crispy'86 wrote:Leon, what rear bar diameter are you using?
Sorry, I'm not sure! It has been in the car about three years, so recollection has faded. Can't tell you much beyond that it's the three adjustment whiteline bar.
Postby Distrb » Mon Oct 09, 2006 12:39 pm
I'm running 20mm adjustable whiteline in the rear of my Ae82. Is a solid bar as well. Same as what Leon is running = Oversteer on demand. Even more so with less grippy tyres. Makes it swap ends a little easier on you if you make a relevant mistake in the corner.
I think the 82 runs a 16mm hollow bar from factory in the rear. So even the same diameter bar, but solid, and adjustable will provide a decent amount more rigidity even on its lowest setting.
Distrb
Regular Poster
Postby Santa'sBoostinSleigh » Mon Oct 09, 2006 1:17 pm
ive got an AE111 rear swaybar you can play with (ie weld tags to adjust etc)
its thicker than my AE92 standard one
im running an adjustable whiteline as well
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby crispy'86 » Tue Oct 10, 2006 7:49 am
I weas just thinking if i got the 18mm solid bar for a start, as it's cheper and i could try the same thing with 2 original bars, 1 clamped to the other, just for testing it out for theory. Hey it's all about learning isin't it?? :D
and 18mm is bit more cost effective for me if i have to buy one. Or what price are you guys looking at for your rear bars that you don't nee? If it'd fit easily
crispy'86
Postby bluemaumau » Tue Oct 10, 2006 9:19 am
interuption, how much are these bad boys worth approx?
Postby Leon » Tue Oct 10, 2006 9:27 am
My whiteline rear bar was about the $300 and some mark as best I recall. This was three years back, so inflation might have kicked in.
E-mail revhead.
Postby bluemaumau » Tue Oct 10, 2006 9:27 am
sweet
Postby crispy'86 » Thu Oct 12, 2006 7:19 am
Prices for the rear bars i've got so far are $160 plus gst for 18mm std bar and $240 plus gst for adjustable whiteline bar my price through work. Anyone else got anything i could have a play with, modify to fit my fx?? I'm not wanting to purchase a new item just yet but experiment with another one to see difference it makes, is there any noticeable difference with adjustable rear bar and just using standard?? I was thinking of just clamping another std bar to my existing one and see if it remedies my problem/ just see what result i get
crispy'86
