l1ttle_d3vil wrote:its obvious its running way too rich, its splurts and misses when i drive but at high revs it seems to go hard!!!
It pours fuel smoke out the exhaust when its running , and it also "hunts" for revs at idle.
i removed the cold start because i suspected it was staying constantly on but still running rich.
jondee86 wrote:Torque (Nm) = (kW x 9550)/rpm
Cheers... jondee86
repowered wrote:it was hunting real bad but then i found the dizzy was fully advanced so i put it back to where i had marked it and it just runs rough now, when you try drive it its like it has no power when u give it some gas. it doesnt hunt as bad but the revs slowly climb, then drop down again suddenly. ill check what you guys suggested. - pulled vacum line off map sensor and it thing almost stalled, dunno if thats atest or not lol
i ddint say that stuff in your quote!
how do you mean its "hunting" for revs? as in revs are lifting and dropping again and again when its idling? this can be caused by vacuum leaks too, or if the idle screw is wound too far back so check that aswell, may be something completely unrelated to the fouling.
$CENSLS1$ wrote:Have you check the timing etc?Is there any kind of oxy sensor in the exhust that you know of?If so it maybe getting a false reading becuase of the split in the exhust below the headers that you told us of and hence feeding the engine more fuel than it should be?Just a thought...?
repowered wrote:got spare water temp sensor from a spare motor, not sure if a FWD bluetop one is diffrent to a RWD one.
l1ttle_d3vil wrote:repowered wrote:got spare water temp sensor from a spare motor, not sure if a FWD bluetop one is diffrent to a RWD one.
just, fwd and rwd should be the same. if they look the same and bolt up then it'll be sweet.
l1ttle_d3vil wrote:yeah, i had that problem too haha. only thing is i cant remember what was causing it. it was either the timing/distributor wiring, or a vacuum leak. check your map sensor vacuum lines too, and make sure you've got the 3rd adaptor thing on the vacuum port blocked off if you're only using too (the black thing that the vacuum lines from the map sensor and fuel reg go to on the manifold)
l1ttle_d3vil wrote:wicked, you'll be stoked once you finally get it going mint and all legal aye!! we only got 98 up here so thats all I run, unless you go to shell which still has 95.
