hellp car miss firing
Postby Diverz_Fxgt » Sun Oct 08, 2006 12:37 pm
hi guys. my fxgt is not firing correctly. its missing a lot. I have changed all the spark plugs and the leads. but im still having the same problem and its also smoking a lot too. so cn any one tell me wat might be the problem.
thanks for the help
Diverz_Fxgt
Postby trdfxgt » Sun Oct 08, 2006 1:36 pm
any history ? like did it just randomly start missing or had you been tinkering ? smoke is likely just to be cos of it not firing in one or 2 of the cylinders
could be a plug off or timing even water in the dizzy could be a number of things
trdfxgt
Postby Diverz_Fxgt » Sun Oct 08, 2006 1:47 pm
it did leak oil from the distributor. i have nt tamppd with the timmin or any thing else. it just started missin buy it self. thanks 4 the advice.
Diverz_Fxgt
Postby Diverz_Fxgt » Sun Oct 08, 2006 1:51 pm
oh dose any1 have a pic of the way the distributor cap should be facing which way i think mines the wrong way. thanks
Diverz_Fxgt
Postby trdfxgt » Sun Oct 08, 2006 3:10 pm
its probably got oil in the dizzy then go to toyota and get a new oil seal also if the dizzy cap is on wrong your problem is pretty self explanitry the leads should be facing almost strait up ot of the cap
trdfxgt
