Rattling Silvertop.
Rattling Silvertop.
Postby Punter » Mon Oct 09, 2006 2:55 pm
Right so here's my problem.
I have a silvertop that's got a bit of a rattle/loud ticking on start up, only until the oil pressure comes up (about 1.5 secs) I'm guessing this is just the clearances'. Also it has developed a little of a thrust for oil (also smoke a little on hard downshifts).
Is this a bid deal? Will it cause huge problems?
Since I'm going to uni next year and will have no money (currently have a job) I'd like to get this fixed before I start uni, in case it turns into a major.
I have a spare 20v head in the garage that's in a bit of a state. It had a BHG and is all gummed up with old oil. but its complete and it works. The engine in the car is unknown KM's but seems to run very well and didn't rattle when I put it in. Should I get the spare head reco'd and swap them or should I fix the head that's in the car?
I don't really have any experience with opening motors up, fixing a BHG was the closest I've gone in the past. (keen to learn though) I just after the best and cheapest solution. I have another car to drive in the meantime so doing the work my self is no biggy.
So any advice or hints would be appreciated
And yea I've searched, can turn up anything much its mostly VVT problems (mine is fine)
Punter
Postby quicklvn » Mon Oct 09, 2006 3:47 pm
For a minute there I thought you might have the same problem as me but mine's a continuous bloody rattling (only at idle) and it pisses me right off :evil: . I'm pretty sure mine is an engine mount of something similar but i'm not sure.
Sorry I don't have any ideas about yours though as it sounds like a different type of rattle.
quicklvn
Postby Distrb » Mon Oct 09, 2006 4:26 pm
punter - Sounds like a rattle from the big end bearings. Other than new bearings or bottom end rebuild, maybe swap out for another good known bottom end?
quicklvn - goes away when driving? if so then sounds like vvt pulley rattle.
Distrb
Regular Poster
Postby Dirtbag » Mon Oct 09, 2006 4:32 pm
Yea, ive got that same problem, pretty sure its vvt pulley as well.
http://forums.toyspeed.org.nz/viewtopic.php?t=30098
check that out, mighty useful
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby Punter » Mon Oct 09, 2006 4:54 pm
Distrb wrote:punter - Sounds like a rattle from the big end bearings. Other than new bearings or bottom end rebuild, maybe swap out for another good known bottom end?
Dam :( Any way to be sure?
So I guess I'll replace the bearing then
Punter
Postby Punter » Mon Oct 09, 2006 4:56 pm
I've done a few track days in the car and its seemed to go strong the whole time.
But I suppose the constant corning of taupo may have starved it. This happened to anyone else?
Punter
Postby Distrb » Mon Oct 09, 2006 5:02 pm
Punter wrote:Dam :( Any way to be sure?
Hard to be 100% sure without seeing/hearing in person, but from what you're describing it sounds like a similar problem to one i had in my '101 fx-gt.
(which eventually died by running a bearing on manfield :oops: )
I wouldnt take my internet diagnosis from your description as being gospel however..
Distrb
Regular Poster
Postby Punter » Mon Oct 09, 2006 5:44 pm
Okay bit more info then, It won't do it unless its absolutly cold.
I drove it at lunch (after sitting for 5 hours) and it did it a little, and then when I went home (sitting for 3.5 hours) no noise at all, ran like new.
Got me worried now, I didn't really want to have to replace/recondition everything but i will if it needs it.
Punter
Postby Pelo » Mon Oct 09, 2006 6:04 pm
My 4age has been doing the same thing just recently, will have a coarse rattle for maybe 1-2 seconds on startup and then it goes away completely. Does it more often when cold, less so when hot, and sometimes will not do it at all regardless of temperature. Maybe oil pump draining between runs? Got me worried too :?
Pelo
Postby slighty_sykotic » Mon Oct 09, 2006 6:11 pm
Pelo wrote:My 4age has been doing the same thing just recently, will have a coarse rattle for maybe 1-2 seconds on startup and then it goes away completely. Does it more often when cold, less so when hot, and sometimes will not do it at all regardless of temperature. Maybe oil pump draining between runs? Got me worried too :?
my guess ^^ oil pump draining out. Might be getting old/worn?
So its got no oil for a couple of seconds and snice its getting old, things are rtattly without oil.
--Sykotic
slighty_sykotic
Postby Caveman » Mon Oct 09, 2006 6:16 pm
If you want to do bottom end, big end bearings are $50 a set, main end are $50 a set and thrust are about $20. These are ACL and are avaliable from partmaster. The genuine toyota is $50 per bearing so $250 for a set. I have been to ACL office and had a lot chat with the guy, they seem pretty good, the only thing they dont have is manufacturing clearences. Bascially for them one bearing fits all. The are copper lead and dont require any run in time.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Punter » Mon Oct 09, 2006 6:46 pm
Is that retail for the toyota bearings or revhead prices?
Because $500+ for a full set of bearings seems a little steep.
Punter
Postby Mr Revhead » Mon Oct 09, 2006 7:15 pm
yeah i can do genuines for some where around $190-200 iirc
acl are ok for a street driven runner.
Postby quicklvn » Tue Oct 10, 2006 8:23 am
Yeh, I think it must be that then. It's only at idle and when under acceleration it goes away. Does this have any effect on power etc?
quicklvn
Postby quicklvn » Tue Oct 10, 2006 8:24 am
lol, bugger I screwed that up, (havn't used the quote function before) :oops:
I feel like a newbie now
quicklvn
Postby Punter » Tue Oct 10, 2006 8:57 am
Mr Revhead wrote:yeah i can do genuines for some where around $190-200 iirc
I try to do 4-5 trackdays per year, are ACL still good enough?
hmmm, you can buy replacement engine thats guaranteed for that sort of money. So maybe I should just put $500 away and wait to see what happens.
Punter
Postby Jebus » Tue Oct 10, 2006 9:11 am
hahaha, thats like going to Mcdonalds and asking if you should have Burger King for lunch :P
Jebus
Postby Mr Revhead » Tue Oct 10, 2006 9:19 am
with ACL you often need to do more machining to get the correct clearances. as mentioned above they do one size to cover the stock 3 sizes.
bearings make a big difference in engines. if you plan on running it really hard i would go better than standard ACL or toyota.
Postby Caveman » Tue Oct 10, 2006 10:18 am
1998 wrote:If you want to do bottom end, big end bearings are $50 a set, main end are $50 a set and thrust are about $20. These are ACL and are avaliable from partmaster. The genuine toyota is $50 per bearing so $250 for a set. I have been to ACL office and had a lot chat with the guy, they seem pretty good, the only thing they dont have is manufacturing clearences. Bascially for them one bearing fits all. The are copper lead and dont require any run in time.
Sorry forgot to mention these are ACL race series bearings.
Best thing to do is go to part master and see the catalogue.
If genuines weren't so expensive id recommend them but for the price you might as well get ACL.
AW11 Track Toy
Caveman
Postby Mr Revhead » Tue Oct 10, 2006 2:33 pm
fair call.
but remember rrp doesnt apply to TSers :wink:
