AE92-AE82 Qs
AE92-AE82 Qs
Postby trdfxgt » Wed Oct 11, 2006 9:29 am
just was on another post and it got me to thinking i have an ae 82 and a ae92 FXGT i lowered my 92 yesterday using ae 82 springs which fit just fine this 92 also has my old 82s exhaust system which i un bolted from one then bolted to the other so now my question is this when i changed the rear springs on the 92 i spotted a multi liink sway bar could i swap this to my 82 ? is there any potential bennifit to doing this it would be a strait forward operation to weld tags to my struts but the body mounts have me guessing
trdfxgt
Postby sergei » Wed Oct 11, 2006 12:22 pm
IIRC AE82 rear suspension setup is very different to AE92, the swaybar on AE82 is connected to suspension arms while on AE92 to the struts. Also rear struts and hubs are different.
Postby Mr Revhead » Wed Oct 11, 2006 12:25 pm
unbolt from donor car
hold up to your car
figure it out.
im sure you can make it work :D
Postby trdfxgt » Wed Oct 11, 2006 1:03 pm
cheers sergei thats the info i needed apart from the tabs on the strut what is different about the rear struts ? is it the top mount hole or something ?
trdfxgt
Postby sergei » Wed Oct 11, 2006 1:11 pm
They are different lenght, place where it is connected to the hub is different thinkness and has different bolt spacing...
Users browsing this forum: Bing [Bot] and 15 guests
