by crispy'86 » Fri Oct 20, 2006 10:08 pm
I'm thinking of using gen 1 3sge valves n one of my 4age big port heads, so does anyone know for fact what the 3sge measures in exhaust and intake valve?? I've measured 4age ones and intake 30mm exhaust 25mm on the face , i.e. what you see whan you look at the combustion chamber. Before anyone says, "go the gen 2 3sge they've got huge valves etc" if it isn't much difference in diameter to compromise the clearance between the intake and exhaust valves then it's going to be a cheap swap. As in spending next to nothing in my terms on buying parts
