Trying to calculate compression ratio...
Postby no_8wire » Sat Oct 21, 2006 2:19 pm
Does anyone know the piston negative dome cc's for a 4agze 8.9:1 piston?
no_8wire
Postby no_8wire » Sat Oct 21, 2006 3:03 pm
oh and the compressed thickness of a stock 4age 16v head gasket...
no_8wire
Postby Bazda » Sat Oct 21, 2006 9:20 pm
no_8wire wrote:oh and the compressed thickness of a stock 4age 16v head gasket...
1.2mm
Postby no_8wire » Sun Oct 22, 2006 8:53 am
is that the same for the 4agze as well?
no_8wire
Postby Mr Revhead » Sun Oct 22, 2006 9:05 am
yes
Postby no_8wire » Sun Oct 22, 2006 9:09 am
sweet cheers guys...any idea on the depression volume in the pistons?
no_8wire
Postby Mr Revhead » Sun Oct 22, 2006 9:13 am
depends how much home and away they have been forced to watch......
:P
sorry i dont. its a long weekend...... sounds like a good project to do today, measure it! :D
Postby Bazda » Sun Oct 22, 2006 9:15 am
putting in the 7A wont be the same as putting in the 4A so you need to put them in and measure the cc's
Postby no_8wire » Sun Oct 22, 2006 9:23 am
Its 0.44mm down the bore to the crown, how ever how would you actually measure the depression in the pistions them selves?
no_8wire
Postby Bazda » Sun Oct 22, 2006 9:28 am
put it into the engine with the top ring on and do ur checks using the water method and glass/perspex
Postby Mr Revhead » Sun Oct 22, 2006 9:33 am
dont forget the vaseline :wink: :D
Postby CAMB01 » Sun Oct 22, 2006 3:19 pm
The dish volume for those pistons is around 6cc's (cubic centimetres), cant be accurate as that was measured from oversized pistons.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
