bfmr turbo's are tiny.
True-no-turbo is right, and you can only measure injector quantities in hp, not boost.
http://www.megamanual.com/v22manual/minj.htm
check this page out.
I worked it out at approximately 215hp at the flywheel at 80%. That would equate to approx 175hp at the wheels, 130kw.
To make that power on a m10, 12.5 afr, id make a wild guess at 13-15psi.
13psi for late model gze bottom end (smallport), 15 psi for early model (bigport)
Your tuner cant be trusted if he asking you what boost to set - has he ever heard of wideband.
kenny - "yours: 0hp @ 0rpm
deaf_homo "currrently yes"
