Help with my 4AGTE, major problems!!
Postby AA63 Celica » Mon Oct 23, 2006 1:07 pm
Hey guys, awesome forums you got going here!!
heres how it goes, its an AA63 celica with a 4agze in it
never had it running
Put a Blue top head on it, bought it ported and polished, put a 1.5mm custom gasket in it, ARP headstud kit
Filled up liqiuds, oil/water, ready to start for the first time until i went to double check oil level, and discovered oil being pushed out dipstick!!
removed sump, lots of antifreeze sitting in sump.
Suspected the custom gasket, so removed and put Genuine GZE gasket in
Same problem, small amount of water sitting on top of #1 piston and yep i had it torqued down hard out.
WTF!!!!????
some suggestions have been:
crack in block
crack in head somewhere
I dont want to take it apart again!! Im only a novice self taught mechanic.
Could the head surface be so far warped that water literally pours out the sump when you fill radiator??
Or maybe they f***ed up the porting, and broke something?
or is it probably the block (which was supposed to have 80,000kms from engine importer!!(or so said the guy i got it off)) come to think about it the engine did come with a turbo and manifolds...but was supposed to be an unfinished project....
Should probably take head off and send to a cylinder head specialist, any one know anywhere that wont charge thousands to look at it or maybe the engine as a whole?
Any help would be greatly appreciated!! cheers
AA63 Celica 4AGTE
KP61 Starlet
TA63 Carina 4age redtop
AA63 Celica
Postby Crucible » Mon Oct 23, 2006 1:22 pm
Im not sure what your workmanship is like so there could be a few possibilitys.
from my experiance its normally the cylinder head or gasket thats at fault, cracked block etc is quite unlikely.
Get the head checked and skimmed, Make sure the block deck is clean enough to eat off and the dowels are in place before fitting the head to stop the gasket shifting, torque to specs inside out.
Crucible
Real Life Mechanic
Postby trdfxgt » Mon Oct 23, 2006 1:29 pm
is the gasket the right way around ?
trdfxgt
Postby AA63 Celica » Mon Oct 23, 2006 1:47 pm
pretty sure the gasket only fits one way ??
yeah i had a qualified mechanic on hand, cleaned it up real good, and the dowls were still in block
How many times can you re-torque ARP head studs??
AA63 Celica 4AGTE
KP61 Starlet
AA63 Celica
Postby Chickenman » Mon Oct 23, 2006 2:06 pm
A few words about studs: A number of engineering tests have demonstrated that studs are significantly stronger than bolts, and the ARP studs are beauties: they are made from extremely high tensile strength steel. Typical head bolts have a lifespan of about two "torquings" -- some would say that even this subjects them to too much stress. The ARP studs are good for more than that, although the very prudent would still be reluctant to reuse any part like a stud or especially a head bolt more than twice.
Baby Jesus
Chickenman
I Am The Walrus!
Postby trdfxgt » Mon Oct 23, 2006 2:48 pm
care full they do fit both ways its been done before
trdfxgt
Postby crnkin » Mon Oct 23, 2006 4:49 pm
And i remember matt dunn saying that the torque specs in the haynes manual, or saomething, has the final torque specs on the page after, and that you dont actually notice the final re torque?
Either that or get everything x-rayed
deaf_homo "currrently yes"
crnkin
Postby matt dunn » Mon Oct 23, 2006 7:25 pm
crnkin wrote:And i remember matt dunn saying that the torque specs in the haynes manual, or saomething, has the final torque specs on the page after, and that you dont actually notice the final re torque?
Hmm, doubt it was me as I've never seen a 4AGE haynes manual in my life,
But someone may have said it.
My bet would be on the head is bent.
Had a similar problem on my car once.
Apart from the head gasket surface of the head being very slighly out of flat (?) we spent a lot checking the head and block for cracks etc etc,
and never found anthing wrong even though it filled the cylinders with water.
Slight skim on the head and a new gasket and has been running fine for over a year since.
Matt
Postby AA63 Celica » Mon Oct 23, 2006 8:41 pm
Awesome, cheers! I will do that, just spotted a mint as blue top head on trademe for $170, has been crack/pressure tested, skimmed and clearences set.
How much roughly can i expect to get that done to my head?
May be worth buying that instead :roll:
AA63 Celica 4AGTE
KP61 Starlet
AA63 Celica
Postby crnkin » Mon Oct 23, 2006 8:41 pm
Matt
hmmm... was a fellow southerener, perhaps redmist.
anywhos
crnkin
Postby no_8wire » Tue Oct 24, 2006 10:19 am
AA63 Celica wrote:Awesome, cheers! I will do that, just spotted a mint as blue top head on trademe for $170, has been crack/pressure tested, skimmed and clearences set.
$60 to skim the head, $80 to pressure test...roughly
no_8wire
Postby AA63 Celica » Tue Oct 24, 2006 11:47 am
sweet thats not too bad, cheers....
How much boost do people normally run their 4agzes on?
think it will handle 18psi with T3 when im thrashing?
AA63 Celica 4AGTE
KP61 Starlet
AA63 Celica
Postby Crucible » Tue Oct 24, 2006 12:45 pm
AA63 Celica wrote:sweet thats not too bad, cheers....
With a proper tune yes, but I wouldnt push too much over 18psi though as a low boost setting.
Crucible
Real Life Mechanic
Postby evil_si » Tue Oct 24, 2006 12:57 pm
if tuned properly and with a decent fuel system 18psi will be fine,
evil_si
