by atmosports » Tue Oct 24, 2006 8:17 pm
You'll find even the Bruns Stainless ones are welded, well the collectors anyway. They aren't all the difficult to make once you've done a few & know the angles etc you want.
As for getting all those nicely curved pipes without any crushing in the bends & all the same length. Well yes you can CNC mandrel Bend them, or just mandrel bend to a template. Else you do it the poor man's way that we've been doing for years & buy boxes & boxes of mandrel bent donuts, 180's etc in the tube size & wall thickness you want & then tig weld them together to get what you want, various tips & tricks to getting them all the same length etc. Only thing is it takes a lot of time to do it properly, especially if you've got to fabricate oval sections & mufflers etc like we've just done to get what we wanted & also to keep the exhaust as close to the undersie of the car we can to try & reduce some more drag(any gain is worth having in a control class)
As for Sand bending, haven't do it in a while, though i have considered doing it for a scooter expansion chamber/exhuast I'm doing slowly at the moment. Basically you need to plug one end, pack it with sand really tighly & then plug the other end so the sand has no wear to go. Yes you will need to heat it & then you simply bend it by hand(probably need another bit of pipe on it to get leverage), heat the next section & away you go until you get what you want. My old man has a set here that he did which is actually older than me & we made by sand bending as mandrel bending back in the days was either mega $$$, not readily available here or hadn't been thought of yet. They still look like new, have no marks or crushed sections on them, however when pressed I was told never again as Mandrel bends & welding sections together is heaps easier & faster.
If you were doing heaps there are hydro-forming & various other methods available but cost would be prohibitive for a one off or small batch. Some of the 2-stroke expansion chambers are hydroformed & they've got some pretty intricate bends & section changes in them, I think basically it'd come done to getting someone to manufacture you moulds/dies etc.
