Hmm. what happened to my car?
Postby HELBND » Tue Oct 24, 2006 3:43 pm
ok, i started my car yesterday, then wandered off to get the neighbours to move their car out of my way. as i was waiting for them to answer the door, i heald a squeal/squawk and my car stopped running.
now when i try to start it, all i can hear is a whirring noise, like the starter is spinning but not engaging. and i cant see how the starter disengaging would stop the engine running. starter seems to still be in place and cambelt seems to be intact.
any help much appreciated
Ben
HELBND
Postby edwagon » Tue Oct 24, 2006 4:08 pm
Maybe the starter didn't disengage and the overrunning clutch overheated, seizing (the shreik you heard) and damaged the sprags in he clutch unit? that would definantly stop it from engaging and turning the flywheel, hence the whirring.
edwagon
Postby flygt4 » Tue Oct 24, 2006 4:12 pm
maybe it swallowed a cat :wink:
flygt4
Postby edwagon » Tue Oct 24, 2006 4:22 pm
I actually know a dreadful story invloving a old holden with solid metal fan, large shroud, sleeping cat and a slow cranking engine..... 8O
If its not the starter itself, check that the engine itself will turn over, incase its a seized idler/aircon/ps pump/camshaft etc etc and the starter is a co-incedence.
Have you tried giving the starter a sharp tap with a hammer or sim? is it manual - will it crash start?
edwagon
Postby crnkin » Tue Oct 24, 2006 5:31 pm
Honestly, this is how you should approach it.
Take one large metal hammer. None of this rubber mallet bull.
Tap the starter very firmly 5 times.
Try to start
Repeat until something happens, or you get bored.
deaf_homo "currrently yes"
crnkin
Postby UTERUS » Tue Oct 24, 2006 5:43 pm
crnkin wrote:Honestly, this is how you should approach it.
Try to start
This man speaks the truth, it worked on my bung starter motors
It is a myth that emos are contagious, and you may be infected. However, it is still widely accepted to wash your hands after physical contact
UTERUS
Postby THA SHZ » Tue Oct 24, 2006 7:12 pm
ben , pull the can cover off and make sure that the belt is tensioned and fine , there is a possibility that it could have slipped a tooth or bunged up , otherwise if that is fine , then give the starter a good few hard whacks and see if that helps , it may just be the solenoid , tis quite common on the 4age starters .
THA SHZ
Postby l1ttle_d3vil » Tue Oct 24, 2006 8:12 pm
Try to start
but would that cause the engine to die while already running? wouldnt a jammed starter just prevent the starter from "firing" again?
or am i just stupid? :roll:
Postby evil_si » Tue Oct 24, 2006 8:21 pm
a loud squeal and engine stopping generally indicates engine seizure.
get a 19mm socket and try and turn the engine over on the crank pulley.
evil_si
Postby DFECTED » Tue Oct 24, 2006 8:41 pm
yeah, check your oil
DFECTED
Postby CAMB01 » Wed Oct 25, 2006 12:51 am
Could have seized and stripped some teeth off the cambelt, the cambelt would still be intact, but have stripped teeth, usually down on the crank sprocket.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
