Dry sump
Dry sump
Postby matt4u » Tue Oct 24, 2006 10:05 pm
Im looking into converting my 5m to a dry sump setup. Does any one have any info on doing this?
Cheers, Matt
SupraCelicaLuxSurf
http://www.offroadexpress.co.nz/images/ ... ui_001.jpg
ADMIN EDIT: oversized image removed
matt4u
Postby Toymad » Wed Oct 25, 2006 9:20 am
Have a look here:
http://www.moroso.com/articles/articled ... stems.html
It should give you a little insight into the workings and setup of dry sumping.
Toymad
Postby cr1mnl » Wed Oct 25, 2006 10:02 am
I can tell you one thing. Its fcuken expensive to set up properly!
www.ology.co.nz
cr1mnl
Postby matt4u » Wed Oct 25, 2006 11:45 pm
cheers for that, Its something I need to look at with the ugly angles I get my truck on. I think I mite have to hold off on doing it till after I bob it and get a cert though but it dont hurt to start resurching it and getting parts together.
Matt
SupraCelicaLuxSurf
matt4u
Postby nzae86 » Thu Oct 26, 2006 9:03 am
From what I have done look to spend between $4 - 6000 on it .
Your addiction to motorsport can only be cured by poverty!
nzae86
