The plugs are BCPR6EP-8 NGK platinums. The plug that looked wet, didnt look oily, just wet, so guessing petrol.
I swapped the number 2 plug to 3 just to verify it wasnt the plug, car was warmish just above the cold mark, gave it some s**t around the block bout 5 min driving, loads of power (well as much as usual), cruised ok, idled ok, got back left it running for 5 more mins, was ok for a minute, but then started steaming out of the exhaust, and pretty bad missfire. So seems it only happens when the car is hot... Pulled out plug 2 (previously plug 3) and it wasnt wet, pulled out plug 3 (the one that was brown before) and the brown crap on it had turned light grey, which is what its supposed to be like afaik.
I just chucked the crusty old NGK iridiums that were in before back in (was running fine before I changed the plugs, but wasnt bad immediately after changing), and once the car heats up, same thing, steam + missfire.
Getting a bit tired of taking the intercooler on and off
Current - 83 Levin AE85 Notch.
Ex - 89 Sprinter - Red Top, 88 Levin - 4agze.
