Hi all
A friend of mine has a silvertop 4age with cams, aftermarket ecu, large fuel pump etc
is it nessecary to upgrade the stock injectors(295cc? & rev limit 8500)
and what are suitable?
the stock ones are low impedance right, so i assume they will be ballasted(cuz of aftermarket ecu which is a wolf btw)
i have seen high impedance 380cc's from a soarer for sale(so would probably need to remove balasting right?)
mr2s are 440ccs? and what about sr20dets? and are they high or low impedance.
What im really trying to find out is if an upgrade is nessecary as i have
a friend with a b18c that maxed is stock injectors at ~7000-7500rpm whith a link+exhaust
any help would be greatly apreciated
