no_8wire wrote:nope...going to pauter rods..stated the rpm I wanted and they said the rods woulf be fine...
no_8wire wrote:im using a smallport 16v though...no quads on this baby...
no_8wire wrote:mmm....well I will try...haha
need to upgrade anyway to handle the boost...isnt that why yours dropped the valve?
no_8wire wrote:I thought as long as you can keep on adding more fuel+air the power will keep rising?
crnkin wrote:Dispite the fact you need bigger cams for 9500, you will need valve springs, that im sure of. I know alistar will be running into issues very soon and hes only running 18psi, I do however not know which ones to get, and im very intersted in someone answering the actually question, now that weve established youll need cams too!
I hear the toda ones are mint for lower boost (under 23ish psi) and NA, but someone said, maybe baz? that theyre only rated 50% higher than the stock spring rates? And i think its baz that knows a good place in oz? might be glenn, cant remember right now
