Custom spring rates
Custom spring rates
Postby Akane » Thu Oct 26, 2006 1:23 pm
Can anyone direct me to the right place for getting custom springs created (that I can customize spring rates), need some 8kg front 7kg rear's
Thanks
Postby KinLoud » Thu Oct 26, 2006 9:22 pm
Do you have standard struts or adjustable height coilovers?
If you have adjustables there are an (almost) infinite range of rate and total spring heights for you to select from.
You sure will rattle your fillings out with those rates?
Ken
Ham
021 408 863
Postby Dell'Orto » Fri Oct 27, 2006 12:00 pm
Snells in Auckland do custom springs.
Postby Akane » Fri Oct 27, 2006 5:06 pm
I have some kind of rangi lowered springs in stock struts atm, thanks to my previous owners.
Looking at getting some KYB + a custom spring rate springs, since my car's certed for lowered springs might as well make the most out of it.
I'll be giving Snells a call, thanks!
