1998 wrote:advantages
shorter intake
better at low speeds
just as good at high speed
evil_si wrote:a bling 600x300 cooler on your average street car imo is a wate of time, and less efficient, but got to have da bling aye!
Lith wrote:evil_si wrote:a bling 600x300 cooler on your average street car imo is a wate of time, and less efficient, but got to have da bling aye!
Interesting - what do you define "your average street car" as? I have a 600x300x76 intercooler for my daily driver and the reason I decided on that size etc is nothing to do with bling. At what point do you think it is justified?? Bearing in mind that your average street car will be running on pump gas, and a lot of the modern turbo ones (ie mine) run a reasonably high 9:1 static compression ratio - its always good to be sure any cooling that can be done is.
evil_si wrote:a proper water to air, none of this toyota or subby crap, like for instance a pwr system, will support high h/p, and is far more efficient,
and isnt designed for the power and type of car its for, but expect to pay top dollar for it,
evil_si wrote:average street car the likes of a gtx, evo, skyline, with no decent mods
a cooler 600x300 is rated at over 600hp,
a 500x300 will support effiecently 540hp
put a 600x300 and 2.5" piping on an evo and the lag is definatly noticable
Dragger_Dan wrote:Case and point - DOCILE - runs 1041hp at the flywheel (last I saw). Running a T51R SPL, methanol, and a big barrel water to air intercooler.
For the same heat capacity a W2A should be smaller than A2A.Lith wrote:I personally think air to air is fine, while a water to air is more efficient I think the extra weight and space taken up by them - not to mention costs, it doesn't make itself worth it.
This is the forte area of W2A. They provide a much more consistent charge temperature regardless of what's going on. A classic example is the street light drags, you wind it up and the core gets hot, then you have to stop. The core is already hot and without a good airflow it'll take a little while to cool down. So the next spurt from the lights ends up with hot charge air.Lith wrote:I ultimately am using an intercooler to release heat for reliability reasons
Stealer Of Souls wrote:For the same heat capacity a W2A should be smaller than A2A.Lith wrote:I personally think air to air is fine, while a water to air is more efficient I think the extra weight and space taken up by them - not to mention costs, it doesn't make itself worth it.This is the forte area of W2A. They provide a much more consistent charge temperature regardless of what's going on. A classic example is the street light drags, you wind it up and the core gets hot, then you have to stop. The core is already hot and without a good airflow it'll take a little while to cool down. So the next spurt from the lights ends up with hot charge air.Lith wrote:I ultimately am using an intercooler to release heat for reliability reasons
Or the unfortunate highway leapfrog. Overtaking a couple of slow cars and a truck (or something similar). Between vehicles you're trapped behind another vehicle with disturbed airflow and a hot core.
In both instances W2A core would be a much more consistent temp.
