replacing VVT pulley for normal 1
Postby lorolla24 » Thu Oct 26, 2006 10:23 pm
Anyboby know how to replace the big heavy VVT pulley for a adjustable cam pulley or just a standard type pulley????
Slivertop, running turbo and NO vvt.
lorolla24
Postby Mr Revhead » Thu Oct 26, 2006 10:44 pm
buy a $$$ toda one.
or get a custom cam
Postby atmosports » Fri Oct 27, 2006 4:58 pm
Give HiTech Motorsport in Pukekohe a call/email, they've done this before a few times. You'll have to make up a gear to suit the standard cam as I don't know of any off the shelf gear that'll bolt on & line up properly. You'll also need to block off the oil feed to the VVT setup, or you can redirect this into the head/cam bearings with a lil work.
atmosports
