evil_si wrote:a/c is fine, powersteering hoses just undo the bracket that holds them and they move enough,
if waterpump is leaking replace cambelt and idler at same time, have to remove it to hget to waterpump anyway,
remove lower stone guards, belts, radiator hose, engine mount, cam belt covers, not a bad job to do,
pretty easy really, dont need much in the way of tools,
17mm socket for crank pulley, T bar pulley to remove crank pulley,
10mm socket for covers, 14mm socket for tensioners, 12mm for adjusters and waterpump bolts. 10mm spanner for waterpump pulley, pulley does come out can be a tight fit between chassis rail thou.
evil_si wrote:dont try and transfer twink marks onto new belt, just asking for trouble IMO.
AE82 FXGT wrote:OK I'll have a shot at it.
Does the cambelt run anything else at all, or is it just the cams and crank?
So I have to get, a cam belt, cam belt tensioner, and waterpump.
Thanks for the help guys.
