What would you expect to happen if your throttle position sensor was broken/faulty?
High idle RPM even when idle control is all the way in? loss of power? Searching Revs? Sort of like an auto when its coldish and even a little when its warm in the fact that you let the clutch out and it accelerates by itself with ur foot completely off the accelerator...
Curious as my car is exhibiting all tehse symptoms and its been suggested to me it may be the TPS....its a Starlet GT btw..thanks
