The new Toyota Diff codes ????
Postby Mr_procrastination » Sat Nov 04, 2006 3:04 pm
How do we decipher the new Diff codes. e.g. A540H-02A and what about when it has an even more random number, e.g. 1160803b ???
Mr_procrastination
Postby KinLoud » Sun Nov 05, 2006 1:41 pm
What car? what build code? FWD RWD?
Found this here: http://toyota.off-road.com/toyota/artic ... ?id=274535
It says
"I could use some help here figuring which codes are common! If your truck or 4Runner (heck, even your car) has code elements which are NOT highlighted above, please email me with your C/TR/A/TM code, engine type, transmission type, model year, stock tire size, and country of purchase of your truck, and I will update the table.
Toyota Differential Code Decoder - Vehicles with 4Txxxxxx... VINs
First Position - Diameter of ring gear Positions 2 & 3 - Ratio Final Position - Differential type
A = 7.5" 01 = 3.42 02 = 3.58 A = 2 Pinion, Open
B = 8" 03 = 4.10 04 = 4.56 B = 4 Pinion, Open
05 = 3.15 06 = 3.91 C = 2 Pinion, OEM Limited SlipWe've found a number is discrepancies in this second table, so don't take it as gospel. The first table has so far proven to be accurate. "
so 02A might be 3.58 final ratio with 2 pinion open diff
Search for toyota tranmissions maybe
Ken
Ham
021 408 863
Postby Mr_procrastination » Sun Nov 05, 2006 9:46 pm
Hi :)
yea id found that while sherching but id also see conflicting info else where so i though i might see if there was some thing a bit more solid.
Thanks for ya time . :)
Mr_procrastination
