f series diff disks
f series diff disks
Postby tenyearguarantee » Thu Nov 09, 2006 10:58 am
hey i have a solid axle f series diff out of a tt132 corona, i was looking at sticking some disks on it and have found a set of disks off an f series diff that was on a cressida. When swapping the hubs over does it matter that the cressida diff had irs?
tenyearguarantee
Postby KE20 » Mon Nov 13, 2006 6:29 pm
youll problyfind the irs diff had drum handbrake, which might be quite difficult to swap aswell as the discs, you really want to swap the disc and get a caliper that does hydrolic and cable and use that
Garage Dori
KE20
Re: f series diff disks
Postby GA61XX » Sat Nov 18, 2006 9:04 pm
tenyearguarantee wrote:hey i have a solid axle f series diff out of a tt132 corona, i was looking at sticking some disks on it and have found a set of disks off an f series diff that was on a cressida. When swapping the hubs over does it matter that the cressida diff had irs?
here in Aus we use corona RT141-142 Disc brake set up :) these set up's will fit the celica "T" diff . IF your diff has the same bearing retainer bolt pattern as the celica's this would be the way to go.
GA61XX
Postby tenyearguarantee » Sun Nov 19, 2006 8:42 am
cheers, will have look into that
tenyearguarantee
