Vacuum gauge for ae111
Postby BZG_UNIT » Sun Nov 12, 2006 6:32 pm
whats the best hose to tap into for a vac gauge in a ae111?
1997 Toyota Trueno
1990 Toyota Trueno GTZ
BZG_UNIT
Postby sergei » Sun Nov 12, 2006 7:05 pm
left side of throttle body (gearbox side) there is round plug in cast, there are a few vacuum tubes coming from it. Use one of them.
Don't use MAP line, fuel pressure line or 4th throttle line.
Postby johntramp » Sun Nov 12, 2006 8:35 pm
what good is a vac gauge?
johntramp
Postby Alex B » Sun Nov 12, 2006 8:44 pm
http://www.obd-codes.com/howto/diagnoseengine.php
Very useful peice of kit be a vac gauge.
Postby TRD_ZERO » Sun Nov 12, 2006 9:37 pm
johntramp wrote:what good is a vac gauge?
Well i wouldnt really buy one myself but one came in the car i bought and it actually tells you how economically your car is driving, like how heavy on juice it is depending on how you drive it lets you know if you are driving easy or not and so on. Its easily explaingd if you can see a good one.
TRD_ZERO
