Redtop on Bluetop ECU?
Postby lexusjeep » Mon Nov 13, 2006 9:40 am
Did a search without success, so will a smallport motor run OK on a bigport ECU? A guy I know is trying to do this, he said the injector plugs are different but the rest seems to plug in.
I'm trying to keep my distance :? :D but I thought I'd ask around for him.
Clint
LJ71 Landcruiser - 1UZ-FE powered
Suzuki SJ 413 - 4A-GE powered - sold
Jeep J20 - 1UZ-FE powered (part owner)
KTM 640 Enduro
If it breaks, build it stronger.
If it doesn't break, drive it harder.
lexusjeep
Postby crnkin » Mon Nov 13, 2006 10:53 am
yep it runs sweet.
You just need the fuel rail as you said, and inlet manifold. You can use either redtop or bluetop throttle body, i used bluetop
runs fine!
sweet!
deaf_homo "currrently yes"
crnkin
Postby lexusjeep » Mon Nov 13, 2006 1:19 pm
Cheers crnkin, I sold the guy my 'ol suzuki & the motor blew on him as he drove home (I did tell him it had a slight knock) so I feel a bit sorry for him. Then he got what was supposed to be a bluetop down from Auckland to bolt in & it turned out to be a redtop... we're gonna have to reverse the throttle body on it too.
Clint
KTM 640 Enduro
lexusjeep
Postby bluemaumau » Mon Nov 13, 2006 3:28 pm
lexusjeep wrote: Cheers crnkin, I sold the guy my 'ol suzuki & the motor blew on him as he drove home (I did tell him it had a slight knock) so I feel a bit sorry for him. Then he got what was supposed to be a bluetop down from Auckland to bolt in & it turned out to be a redtop... we're gonna have to reverse the throttle body on it too.
Clint
guted, was it hard converstion
Postby ChaosAD » Fri Nov 17, 2006 5:39 pm
For the bluetop ecu to run a smallport redtop, you will need the bluetop dizzy, injectors and possibly a few other things. But u can just pinch them off the blown bluetop
ChaosAD
Postby crispy'86 » Sat Nov 18, 2006 9:07 am
And T.P.S has different plug between bluetop/ redtop tvis. I'd imagine smallport would be same,
crispy'86
Postby crnkin » Sat Nov 18, 2006 11:12 am
ah yes, i was running smallport block and manifold only, rest of everything was bluetop, incl injectors etc...
shouldve said that i guess...
crnkin
