Temperature guage behaving iratically:(
Postby 2fas4u » Mon Nov 13, 2006 9:20 pm
hi guys, the Temperature guage on my 90 MR2 Turbo is behaving very irratically. one minute the needle would jump to past the hot point and stay up their while it's idling (when stopped at traffic lights or simply when the car is not moving)and would drop back to the middle when start moving again. it would sometimes jump to past the Hot point again after a good boosting, and sometimes it would stay at the normal level. After leaving the car parked for 10-15mins with engine off while i go do shopping and then return to turn car on again, the temperature needle would surge past hot point immediately. however when boosting down the motorway or State highway, the needle rarely ever leave the nomal reading. any ideas? stuffed guage?, stuffed thermostat or both? any one got a pic of which plug is the temperature sensor? cheers
2fas4u
Postby bluemaumau » Mon Nov 13, 2006 9:28 pm
replace your therm,ostat is your radiator fan working?
Postby Lloyd » Mon Nov 13, 2006 9:29 pm
Air lock in the cooling system?
Postby 2fas4u » Mon Nov 13, 2006 9:45 pm
where is the radiator fan on the MR2? is it the fan that's in the engine bay at the back on the drivers side? or is that fan for the intercooler? if it's that fan then yes it's working. how do i replace the thermostat and where is it found. if it's air lock how do i unlock it? sorry about so many question. first time had this happening to me.
2fas4u
Postby Kender » Mon Nov 13, 2006 10:04 pm
2fas4u wrote:where is the radiator fan on the MR2?
Strangely enough it's kept in the front of the car, on the back of the radiator :wink:
Do those fans turn on when the aircon is turned on? (They should)
'84 AW11 SC racecar "RDDWRF"
'92 SW20 GT-S
'91 GT Legacy wagon
Kender
Postby Alex B » Mon Nov 13, 2006 10:11 pm
With an MR2 water system i wouldn't touch it unless you have a bit of a clue about what your doing. So easy to stuff it up.
Postby sergei » Mon Nov 13, 2006 10:11 pm
if the guage moving really fast , no way it is air lock or overheating problem. I had similar problem on my GT4, it turned out to be loose plug on guage sender. 1 cable tie and it is all fixed.
Postby 2fas4u » Mon Nov 13, 2006 11:06 pm
never realised there's another fan behind the radiator:O
2fas4u
Postby ollieboy » Tue Nov 14, 2006 12:15 am
sergei wrote:if the guage moving really fast , no way it is air lock or overheating problem. I had similar problem on my GT4, it turned out to be loose plug on guage sender. 1 cable tie and it is all fixed.
Yeah same thing on a friends ATV Kart, thats my bet.
ollieboy
Postby 2fas4u » Tue Nov 14, 2006 8:20 pm
cheers, just incase it was a thermostat, how much are replacements from toyota? MR Revhead still here?
in regards to the temperature guage on the dash, where is the signal for that come from? was it from the temperature sensor that's hooked up to the radiator itself or is the signal sent from a sensor that's on the engine block? cheers.
2fas4u
Postby no_8wire » Tue Nov 14, 2006 9:08 pm
About $30 odd dollars IIRC...
no_8wire
Postby 2fas4u » Tue Nov 14, 2006 9:26 pm
wats IIRC? where can i get one from?
2fas4u
Postby Alex B » Tue Nov 14, 2006 9:39 pm
IIRC = if i recall correctly. And IIRC they are alot more expensive than that for some stupid reason. Gen IV turbo was something like $70 trade from repco??
Postby no_8wire » Tue Nov 14, 2006 9:41 pm
if i remember correctly...and you will find his email here
http://forums.toyspeed.org.nz/viewtopic.php?t=44317
no_8wire
will give warwick a call, cheers dude.
Postby 2fas4u » Tue Nov 14, 2006 9:50 pm
check price first.
2fas4u
