My little bro has LED truck taillights on the back of his b1600 so the indicators flash too fast. He went to an autosparky and the guy sold him a 2 pin, non load sensitive flasher relay. He got home and took the old flasher relay out and found that its a 3 pin relay. Can he wire it up to work with the 2 pin relay? 2 pin has a posi terminal and one labeled L. 3 pin has on labelled E, one called B and one called L.
Any ideas on wiring it or should he just take it back and try swap for a 3 pin relay. If so will the wiring be the same as the one from his ute?
