De-spoilering an ae111
Postby BZG_UNIT » Thu Nov 16, 2006 6:23 pm
Whats the best way to go about this... and fill in the holes? i un-done the bolts byt seems to be some adhesive shit holding it to..
cheers guys in advance!!
1997 Toyota Trueno
1990 Toyota Trueno GTZ
BZG_UNIT
Postby RED TOP MR 2 » Thu Nov 16, 2006 9:22 pm
hit the adhesive with a heat gun and sum dental floss.clean off any excess with turps.best way to fill holes is welding but this is expensive and requires panel and paint.you can pop sum christmass trees into the holes or bog them.just dont leave them they will rust.
RED TOP MR 2
Postby antonio » Mon Nov 27, 2006 7:17 pm
Hey dude if u wana o a proper job without welding, would be to bog it, but before you do it, bang the edges of the hole all around the hole, so it has a slight slope, this will give the bog a better and stronger platform to sit on, you could put something in the hole aswell. I would say don't use the soft bog, use a metal tech fibre bog it will work better and you wont get cracks. I have done it to mine and its sweet. like the spoiler wasn't even there.
AK
antonio
Postby gleem » Mon Nov 27, 2006 7:27 pm
thanks this sort of answered my question as well, how much to get it welded and painted professionaly?
gleem
Postby 5afe_Toy » Mon Nov 27, 2006 8:36 pm
you could use rubber plugs/bungs , thats wat i was gona do 8)
5afe_Toy
Postby RED TOP MR 2 » Mon Nov 27, 2006 8:57 pm
panel beating is aound $60 an hour maybe $300.have a go yourself with $50 off stuff from repco take it easy read intructions and you may get some pretty good results.
RED TOP MR 2
