phat_levin wrote:the bands are green red black black and brown. the packet says 510. i didnt have a problem wen i had just the light, its only since iv added the switch in for the vvt that this has started happening......
wat does ur switch do? i have mine set up to have VVT running normally, on all the time, or off all the time...
A technical term for the diode you're putting across the LED...phat_levin wrote:thanks for the help guys. what is a fly back diode?
i will try putting a diode across the led and see what happens.....
MrOizo wrote:postfach wrote:Digger!!!
sh*t thats a awesome pic!!!
