02 rav4 diagonistic plug
Postby maxium » Sat Nov 25, 2006 5:06 pm
can any one tell me where it is?
cant find it under the bonnet and am i able to brige te and e1 to get the falut codes out of it? if i do find it?
maxium
Postby postfach » Sat Nov 25, 2006 6:05 pm
have a look around the drivers footwell, i think there is one there in some cars? should be able to bridge them yeah.
postfach
Postby slighty_sykotic » Sat Nov 25, 2006 6:28 pm
You wont be able to. It will be at least obod II.
You will need a scanner, not just bridge the terminals.
--Sykotic
slighty_sykotic
Postby Mr Revhead » Sun Nov 26, 2006 9:25 am
yep, new generation toyotas require a scann tool. the lastest have a real tricky one too.
Postby maxium » Sun Nov 26, 2006 11:32 am
i was guessing it needed a scan tool. i found a plug under the dash on drivers side.
i think it has a tps problem after speeding up to 50 or 60 when you back off the throttle it misses once real hard then curises on light throttle nicely
also feels really lean as you go to drive off
any ideas?
maxium
Postby maxium » Sun Nov 26, 2006 9:02 pm
anyone?
maxium
Postby Mr Revhead » Sun Nov 26, 2006 9:25 pm
o2 sensor, not uncommon to fail
iirc they have 4
Postby Alex B » Mon Nov 27, 2006 3:26 pm
Are they not just OBD2 revvy?
Postby Mr Revhead » Mon Nov 27, 2006 3:38 pm
not 100% sure on the RAVs.
the latest hilux requires a different scanner than previous model toyotas.
dont know if its OBD2 or what ever though. apparantly the info gained is a heck of a lot more, and they can alter various parameters on the ECU whereas the older ones just read info.
Postby CozmoNz » Mon Nov 27, 2006 3:55 pm
Mr Revhead wrote:o2 sensor, not uncommon to fail
iirc they have 4
4 o2 sensors?!?!
Rayne For President!
CozmoNz
Postby Mr Revhead » Mon Nov 27, 2006 3:59 pm
yep. the 2az engine has one per cylinder.
quite a few now have more than one 02 sensor
Postby maxium » Mon Nov 27, 2006 8:54 pm
hey all the rav has been in to toyota twice now for this above falut had new plugs fitted first go and second time round they put scan tool on it and went for a drive but failed to find anything yet as we left toyota shop it did i just down the road on way home.
anyone else got an ideas? 600 bucks down the drain so far and still no fix
maxium
Postby maxium » Tue Nov 28, 2006 9:43 pm
bump
maxium
Postby maxium » Sun Dec 17, 2006 8:47 pm
bump :oops:
maxium
Postby Mr Revhead » Sun Dec 17, 2006 9:01 pm
have you gone back and said its still doing it?
Postby maxium » Thu Dec 21, 2006 10:24 pm
yea we did and it was looked at again with scan tool hooked up but i got the imperssion that they didnt give a shit and said they couldnt find anything wrong with it. that was when i thought i could put it in check mode and drive it till the miss hapened. but seems like i cant now
maxium
Postby matt dunn » Fri Dec 22, 2006 12:33 am
maxium wrote:yea we did and it was looked at again with scan tool hooked up but i got the imperssion that they didnt give a sh*t and said they couldnt find anything wrong with it. that was when i thought i could put it in check mode and drive it till the miss hapened. but seems like i cant now
Where are you located?
Postby Mr Revhead » Fri Dec 22, 2006 8:48 am
yeah, where are you?
toyota dealers are generally pretty good with customers
Postby maxium » Thu Dec 28, 2006 9:45 pm
were in chch. i had a chance to hook a snapon scan tool up to the rav on wednesday, it had one fault logged
VVT system malfunction,
i cleared it and went for a drive wile looking for a spike or flat spot on the graphs , only thing i saw that seemed odd was te timing went to negitive 13.5 degrees at one point , my time was limited and didnt get a chance to cross check graphs for engine load when it changed the timing at that point.
rechecked the fault codes and VVT system malfunction had logged again,
was pissed that i couldnt get it to miss like it does often cruising round chch. im stuck now on what i should be looking at with the VVT as to the fault it logged,
maxium
Postby maxium » Mon Jan 01, 2007 1:04 pm
bump :oops:
maxium
