turboing my silvertop engine .HELLLLP!
Postby antonio » Sun Nov 26, 2006 7:33 pm
Hey guys I need to know what i need to turbo my ae101 silvertop.
I know i need some forged pistons and rods, or 4agze pistons and rods.
I got a intercooler and 1994 legacy gt 1st turbo. But I need some info on what i need. :roll:
AK
antonio
Postby bluemaumau » Sun Nov 26, 2006 7:35 pm
have you searched man? what do you want to know exactly, stuff you need depends on other stuff your using(turbo size etc)
COuld this work
Postby antonio » Sun Nov 26, 2006 7:35 pm
Could take the ecu etc... of the 4agze. I only want about 9, 10 pound boost? 8)
AK
antonio
Postby antonio » Sun Nov 26, 2006 7:40 pm
bluemaumau wrote:have you searched man? what do you want to know exactly, stuff you need depends on other stuff your using(turbo size etc)
What do I need exactly to turbo my car. Don't no about turbo size but i have one of a 94 gt wagon which is the 1st turbo.
AK
antonio
Postby bluemaumau » Sun Nov 26, 2006 7:41 pm
depends how hard you go, how much cash you got?
Postby flygt4 » Sun Nov 26, 2006 7:48 pm
how much money do you want to spend and how much can you do yourself?
how much power do you want?
it is possible to turbocharge the standard bottom end depending on desired power output.
if you have less then basic machanical skills then do you have a mininum of 3k as its far from a 5 minute job, and you will need to muck around with tuning and ecus if you want it to last more than 5 minutes.
if you're paying somebody else then it would be over 5k if you included assembling a suitable lower compression bottom end etc.
you might want pause, take a minute ,and have a think about how much power you want and how much money/time you are prepared to spend.
flygt4
Postby antonio » Sun Nov 26, 2006 8:00 pm
well i have the engine out of the the car and ive takin the head off.
Everything I can do myself except the ecu part but I was persuming that i could spend some money in the ecu area, apart from that I can change the pistons rods and turbo, extractors etc... Just need to know what I need, and off what car. I was thinking get every thing of the 4agze like ecu, loom pistons and rods, what do you think bro!
AK
antonio
Postby bluemaumau » Sun Nov 26, 2006 8:04 pm
what power do you want?
Postby RED TOP MR 2 » Sun Nov 26, 2006 8:08 pm
buy a 4agze???jus an option
RED TOP MR 2
Postby CAMB01 » Sun Nov 26, 2006 8:09 pm
You wont be able to use a 4agze ECU with a 20v.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby antonio » Sun Nov 26, 2006 8:13 pm
Yeah but isnt the Ae101 silvetop motor the same az the ae1o1 4agze engine just different pistons and rods and ecu
AK
antonio
Postby no_8wire » Sun Nov 26, 2006 8:15 pm
no.
all 4agze are 16v...silver/blacktops are 20v
no_8wire
Postby bluemaumau » Sun Nov 26, 2006 8:17 pm
all the auxillarys(think thats what thyre called) , sensors, alternators are different too i think
Postby flygt4 » Sun Nov 26, 2006 8:19 pm
heres a basic shopping list of what you'll need , feel free to go and get prices for it all.
you can either buy a 2nd hand 4agze engine and use you 20v head and risk it or try and use some of your existing gear.
-your silvertop rods will be ok. they are the same as ae101 4agze.i use them and have no issues.
-8.9 CR 4agze pistons , id buy them new from toyota , go and price them
- trd headgasket might come in handy for reliability sake. i use 0.8mm 3layer steel.
- for power up to ~145kw use tdo4, t3, t25 turbo , for higher power use tdo5 , t3t/4, t28, vf24, ht18. i wouldnt bother with an external wastegate unless you were considering running over 17psi on any of the larger turbos.
how much power you want? if over 150kw atw then you'll need larger injectors ~($200-300) and probly a larger fuel pump (~$270)
go for a decent i/c with not too large a core size , around evo size is good but dont rely on old 2nd hand ones to be efficient. (~$250 off trademe)
dont cheap on joiners , 300ish worth of samco joiners to plumb in a typical front mount setups worth of stuff.
you will need an aftermarket ecu , to run vvt and be able to tune for boost etc. allow probly 1500 for an ecu and wiring on top of that. id allow (~600ish) for tuning too.
fabrication- can you weld effectively? you need to allow for the fabrication of i/c piping, exhaust manifold,inlet collector, piping for air intake, oil drain to sump etc what you spends depend on what you can do yourself.
id also leave myself up to 1k for random shit that you never thought about at the start, :lol: because something always goes wrong. ive probly missed loads too , thats all i get off the top of my head.
it helps if you ask specific questions too , not just , what do i need to turbocharge my silvertop?
flygt4
Postby antonio » Sun Nov 26, 2006 8:20 pm
true bro thats right.
I was told I can take the pistons and rods from the 4agze to thake compression down and so it can handle the turbo but what u think. could you give me a list of things I would need to get this puppy up and running willing to spend around 2 to 3G
AK
antonio
Postby no_8wire » Sun Nov 26, 2006 8:23 pm
:lol:
3g will get you the pistons, rods,turbo and ECU(installed)
Not much else Im afraid...
no_8wire
Postby flygt4 » Sun Nov 26, 2006 8:25 pm
heh id be pretty happy if i could do that for 3k :lol:
flygt4
Postby antonio » Sun Nov 26, 2006 8:25 pm
First of all I can get the pistons and rods cheap and install them myself.
Apart from that what ecu and where could I get it from bro!
AK
antonio
Postby no_8wire » Sun Nov 26, 2006 8:28 pm
Links seem to be going on trademe for around 970 new...plus the $$$ to install...those new pistons? If not make sure you get new rings etc...(250)
no_8wire
Postby flygt4 » Sun Nov 26, 2006 8:30 pm
you get what you pay for.
links are cheap and basic, and seem to be most common for these setups.
they are also quite crap really :lol:
i mentioned to my tuner i wasnt happy with my link , and he suggested an autronic smc as an alternative that has the features i wanted and ease of tuning. if i was to do the change now , with my existing setup running correctly i would be allowing myself 2.5-3k for it installed and tuned.
you could probly get a link in and going for 2k.
flygt4
Users browsing this forum: Google [Bot] and 17 guests
