Grinding noise - gbox??
Postby minijrocks » Sat Dec 09, 2006 1:26 pm
Ive got a trueno ae101 and when in first gear sometimes and reverse most times, there is a grinding noise when releasing the clutch (about 3/4 of the way out). It sounds like its not in gear but its not as loud as that, but has a whyning grinding sound.
2nd 3rd 4th 5th etc are great, no slips.
Only seems to happen when the car has been driven, then parked for 20mins or so and go to reverse out of a park and i get the sound. Once the clutch is right out its fine, its just when riding it, it makes this sound.
minijrocks
Postby trueno_20v » Sat Dec 09, 2006 11:46 pm
what does it sound like when in neutral and then letting the clutch out? is there a grinding noise?
ADMIN EDIT: signature too large
trueno_20v
Postby RedMist » Sun Dec 10, 2006 10:53 am
trueno_20v wrote:what does it sound like when in neutral and then letting the clutch out? is there a grinding noise?
You thinking the same thing I am... thrust bearing?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby minijrocks » Sun Dec 10, 2006 8:41 pm
nah no sound at all (apart from a little squeak from the clutch going in and out)
minijrocks
Postby 79rolla » Sun Dec 10, 2006 8:44 pm
cheeked oil leavis?
past: AE82 FXGT
79rolla
Postby minijrocks » Fri Dec 15, 2006 8:23 pm
went 2 a workshop today and they had a play, thought it was the clutch.they checked the gbox oil and was fine. said as the clutch wasn't slipping no real need for it to be replaced yet.... :roll: might get a second opinion somewhere, any reccomendations??
minijrocks
Users browsing this forum: Google [Bot] and 26 guests
