HRT wrote:With the right offset you can get 215s in easy enough. Dont know what offset my old mags were but 215/35/R18s fitted under with it lowered and without lipping the guards, no rubbing
Punter wrote:Ewwwww... Tri-Spokes.
Nah, sounds like you have it sorted.
factory offset is +38 so you need somewhere around +40 for 6.5" rims.
Ahh.. yes my mistake. I was thinking more for the looks. (not sticking out from the car) But I forgot that ae92's don't have much room in the rear, my wheels rub on the rear struts in my mates ae92, but aren't even close on my ae101.Gavin wrote:I'm a little confused about that second part. So your saying I would want a higher offset for wider wheels? But that would make them even less likely to fit..
Punter wrote:wheels rub on the rear struts in my mates ae92, but aren't even close on my ae101.
Can't say I actually looked at what caused it, but it rubbed on the shock body.Santa'sBoostinSleigh wrote:Punter wrote:wheels rub on the rear struts in my mates ae92, but aren't even close on my ae101.
if thats the case, i may have to do a conversion on the rear of my ae92.
you reckon its the struts or the rear hubs that make it different??
1998 wrote:i fit 205/50/15 on the front of my ae92 no problems.
