4age running crap -> distributor ?
Postby johntramp » Fri Dec 15, 2006 4:02 pm
Hey. My car was running sweet earlier in the week and now all of a sudden the car is running crap, backfiring out the intake, doesn't want to rev, no power at all etc...
I am getting this error code
I have checked continuity between the 4 pins and the distributor and they are all fine. There is a 250ohm resistance between pins NE and G1 but nothing between any of the others. Should there be something between NE and G2?
I am thinking I have to replace the distributor but am not sure and don't want to buy a new one until I know what is wrong.
johntramp
Postby johntramp » Fri Dec 15, 2006 10:31 pm
What is the difference between G1 and G2 ? I see on the 16v 4age's they only have G, NE and G- where the 20v's have 4 pins.
johntramp
Almost sounds like
Postby andyztouring » Sat Dec 16, 2006 10:32 am
Almost sounds like it has slipped/jumped a tooth on a cam cog,check it out before wasting money replacing anything.
andyztouring
Postby johntramp » Sat Dec 16, 2006 5:19 pm
why would the ecu be showing errors at the dizzy?
johntramp
Postby johntramp » Wed Dec 20, 2006 12:46 am
I replaced the distributor yesterday, and the car seems to be running well again except the error 12 hasn't gone away after resetting the ecu. I haven't had a timing light on it yet but I don't believe that could have anything to do with the error.
Is there any way the error could be stuck in memory or am I likely to have another problem somewhere.
Both G and NE circuits seem fine and I have replaced the distributor. What is the chance of having a faulty ecu if the car seems to be running right?
johntramp
Postby johntramp » Sat Dec 23, 2006 6:50 pm
Anyone? :(
I am still getting an error 12 even tho the car seems to be running ok.
Is this something to be worried about?
johntramp
Postby johntramp » Sun Dec 24, 2006 8:24 pm
im not getting much help here :(
is there any chance that the igniter could be causing this error?
johntramp
Postby matt dunn » Sun Dec 24, 2006 10:38 pm
Chances are you did not clear the error code properly.
Make sure you can clear it before you start the car,
then if it comes back you know it is a re-occouring fault,
not just a left over fault code.
Matt
Postby johntramp » Mon Dec 25, 2006 12:10 am
i have had the battery left disconnected for a few hours so I am fairly sure the memory is cleared. also it is not quite running 100% - doesn't have the same kick in the higher revs as it used to
johntramp
Postby big_boy » Mon Dec 25, 2006 8:30 am
have you checked wireing & plugs for restance
big_boy
Postby johntramp » Mon Dec 25, 2006 10:18 am
yes, there is continuity over the G and NE circuits
johntramp
Postby big_boy » Mon Dec 25, 2006 11:15 am
thats not what im questioning im asking is there 0-0.7 ohms restance in the wires from the ECU to the componet & are the plugs clean & not croded
big_boy
Postby johntramp » Mon Dec 25, 2006 12:14 pm
ah ok, I just checked them and they have 0 ohms on each of the 4 wires going between the distributor and ecu.
johntramp
Postby big_boy » Mon Dec 25, 2006 1:30 pm
ok do you no exactly what error 12 is ???
big_boy
Postby johntramp » Mon Dec 25, 2006 1:45 pm
no more than what I have posted at the top of the thread. There seems to be nothing more about it in the tech handbook
johntramp
Postby big_boy » Mon Dec 25, 2006 2:22 pm
have you got a good earth ???
big_boy
Postby johntramp » Mon Dec 25, 2006 3:34 pm
when the ecu is plugged in and I unplug the distributor there is 0 ohm to ground from the white wire (G-) which is not there when the ecu is unplugged
johntramp
Postby big_boy » Mon Dec 25, 2006 11:22 pm
whats the restance between G & NE
also do you have a good condition rotor
& have you fitted an after market rev counter ???
big_boy
Postby johntramp » Mon Dec 25, 2006 11:42 pm
Going by memory it was around 200 ohms between G- and NE. I have just replaced the whole distributor so I would hope that the rotor is in good condition.
This motor is not factory, so I have wired the rev counter in the dash from the -ve of the coil. I realized later that there was a wire from the igniter for the tach. I don't remember if I swapped it over or not, they probably are the same wire anyway...
johntramp
Postby matt dunn » Tue Dec 26, 2006 2:12 am
johntramp wrote:i have had the battery left disconnected for a few hours so I am fairly sure the memory is cleared. also it is not quite running 100% - doesn't have the same kick in the higher revs as it used to
Did you press the brake pedal to release the power from the capacitors in the ECU?
If you reconnect the battery and then recheck the codes before you wind the car over,
is the code still there because if they cleared properly, the code should not come back untill it see's RPM from the dist or a cranking signal on the start wire??
Users browsing this forum: Google [Bot] and 29 guests
