rotating turbos
rotating turbos
Postby l1ttle_d3vil » Sat Dec 16, 2006 4:31 pm
ive got to rotate the turbo ive got here, but not sure which set of bolts to loosen...
pretty sure I was told at some point its the ones on the right, but not sure. ive unbolted them but it doesnt seem to want to rotate anything...
looks more like it'd be the set of bolts on the left (4 of them all together), can someone confirm this for me?? don't want to force anything wouthout knowing what its gona do!
cheers.
[img]image%20has%20been%20deleted[/img]
edcit - turbo is a vf10 if it helps...
Postby loose_unit » Sat Dec 16, 2006 4:53 pm
Do you need to rotate the core or do you just need to rotate the compressor housing, coz it could be either.
Bolts on the left are for rotating the core, but it will be mega tight, may need to get some heat in there to get it loose. Same deal for compressor housing, will be tight as hell, but should come free with some effort.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby l1ttle_d3vil » Sat Dec 16, 2006 4:59 pm
oh sweet, either of them really. just gota see how everything lines up, might start with the compressor housing first seeing as that'd be the easiest ... and I dont have a gas torch handy :lol:
thanks for that.
Postby TRD_ZERO » Sat Dec 16, 2006 5:33 pm
When you rotate the compressor housing like that in some cases you might struggle to get the wastegate actuator to fit back onto the housing, as the holes they were originally bolted to are now in a different position but this is easily fixed by drilling new ones. This could be different in your case but thought id let you know anyway.
TRD_ZERO
Postby l1ttle_d3vil » Sat Dec 16, 2006 7:36 pm
hmm well i rotated the core piss easy, but cannot get the compressor housing to turn at all. any special tricks to it?? ive got the core where I need it, but need to rotate the compressor housing so it doesnt hit the oil filter and also so the actuator fits, as you said...
Postby Zak » Sat Dec 16, 2006 7:38 pm
Have you tried tapping the back of it with a rubber hammer?
Zak
Postby l1ttle_d3vil » Sat Dec 16, 2006 7:42 pm
got it now, the whole compressor housing came off in the end :roll:
took a hell of a lot more force than the core of it though...
Postby Crampy » Sat Dec 16, 2006 8:45 pm
That's weird, my VF10 was the opposite. The compressor cover came off sweet as, but the core was a nightmare to rotate.
Then, I ended up getting a new exhaust manifold and the turbo needed to be top mounted again, so what a waste to time :oops:
Crampy
Postby l1ttle_d3vil » Sun Dec 17, 2006 11:15 am
yeah I got both loose by hand in the end, but it took two of us for the compressor housing - one holding a bar through the flange studs and me twisting the housing...
how important is it to have the turbo mounted on the right angle? the compressor housing comes pretty close to the oil filter but if its on an angle as pictured below its fine. the pic below would be worst case scenario, i could level it up quite a bit more than this probably.
is this going to cause problems with the oil drain or anything like that?? im guessing it wont, but im no expert on turbos :lol:
Image[/img]
Postby SUBARUCONVERT » Sun Dec 17, 2006 1:13 pm
U were lucky, usually on the IHI turbos the exhaust housing rusts to the CHRA and u need to heat the ex housing to red hot and bash the shit out of it. with an angle like that u may have thrust washer wear problems. probly ok
3ST150
SUBARUCONVERT
Postby Phothog » Sun Dec 17, 2006 2:55 pm
l1ttle_d3vil wrote:how important is it to have the turbo mounted on the right angle? the compressor housing comes pretty close to the oil filter but if its on an angle as pictured below its fine. the pic below would be worst case scenario, i could level it up quite a bit more than this probably.
Very imortant, with the turbo at this angle, the oil will build up in the bearing housing and cause it to leak out the turbine end ring.
the turbo should be dead level...
Phothog
Postby l1ttle_d3vil » Sun Dec 17, 2006 3:41 pm
good point...how dead is "dead level"? will it be sweet to just set it up by eye? should be able to get it pretty level and just clear the oil filter :lol:
Postby SUBARUCONVERT » Sun Dec 17, 2006 4:55 pm
doesnt have to be 180deg flat
3ST150
SUBARUCONVERT
Postby Crampy » Sun Dec 17, 2006 6:17 pm
You should still buy that manifold off me and chuck ya VF10 on that. It'll fit up sweet and the turbo will be sitting at the right angle for the drain to work sweet.
Crampy
Postby l1ttle_d3vil » Sun Dec 17, 2006 7:02 pm
i was waiting for you to get back to me with the dimensions etc of it!
got this one sussed now anyway. i found a stainless manifold on trademe, bling bling y0 and for a real good price!
its just a side-mount manifold and setup for a t25 turbo though but some easy mods will soon fix that up, just looking at different ways around it.
will I run into problems if I stuck with the t25 flange on the vf10 turbo? im not worried around the stud pattern, that can be fixed. my main concern is the difference between the outlet of the manifold, and the inlet of the turbo. heres a pic of the t25 flange gasket over the vf10 flange, its only a minor difference.
will it effect performance much? just might be easier if I dont have to cut the whole flange off...
Postby bluemaumau » Sun Apr 13, 2008 4:58 pm
do the bolts need to be torqued to a specified value, once the core or housing are rotated?
Postby cat007 » Mon Apr 14, 2008 9:39 am
Oil feed should be between 10 and 2 - max....
Idealy straight up and down
Postby bluemaumau » Mon Apr 14, 2008 2:08 pm
thats already posted above. :?
Postby slammed_integral » Mon Apr 14, 2008 3:01 pm
i have to do this aswell on a wrx td04, as the oil drain is pointing up and needs be rotated 180 degrees. will the bolts on the left rotate the core on my turbo aswell?
http://www.cardomain.com/id/slick_ep
there is nothing sour cola worms cant fix...
slammed_integral
