Diameter of gtz pressure plate or flywheel?
Postby TRD_ZERO » Sat Dec 23, 2006 10:53 am
Im wanting to know the diameter of bot ae101 and ae92 pressure plates. As i have a flywheel and pressure plate from a gtz but i dnt know which one. Any measurements of either the flywheel or pressureplate would be much appreciated.
TRD_ZERO
Postby bluemaumau » Sat Dec 23, 2006 11:17 am
alyryt ive just been into the garage,
not exact
ae92 flywheel(afm)- 225mm (surface area)
ae92 p plate (afm)-265mm
ae101 flywheel- 232mm (surface aerea)
ae101 p plate- 270mm
Postby TRD_ZERO » Sat Dec 23, 2006 3:45 pm
Nice thanks for that its most helpful.
TRD_ZERO
Postby TRD_ZERO » Sat Dec 23, 2006 3:53 pm
I measures the pressure plate that i have and its 227mm in diameter surface area but it fits on the ae92 gtz flywheel. Am i able to use this pressure plate?
TRD_ZERO
