Hiace Gearbox Q ?
Hiace Gearbox Q ?
Postby R15 » Mon Dec 25, 2006 12:46 pm
ive got a hiace. it has a slushbox
ive got a parts hiace. it has a manual
my road going hiace has a cable speedo
my parts hiace has a electronic speedo
am i able to unbolt the electronic thingee at the back end of the box and stick the cable drive in there instead?
it appears as tho it will fit
if it wont, i will just give up and deal with the fact that my van is auto
R15
Postby big_boy » Mon Dec 25, 2006 1:27 pm
yes you can if they are the same series box altho you may have to change drive gears depending
but rembour if your going auto-manual you may find it very high geared if you keep the autop diff & also if you change the diff you will need to also change the spedo to sute your new diff
big_boy
Postby R15 » Mon Dec 25, 2006 2:01 pm
so how do i tell if its the same series box?
(ive now realised working on hiaces is a bitch!!)
and is there an easy way of getting to the window wiper pivots as my one is severely worn on the left one, i have one to replace it with off the other van, but i ended up bending and breaking things on the donor to get to it
as for higher gearing, i see that as an advantage as i dont use it for any significant loads really anyway, and first is pretty useless on a manual hiace anyway in standard form
R15
Postby R15 » Mon Dec 25, 2006 2:14 pm
the auto van says TRANS / AXLE : 8E2 G142
the man van says TRANS / AXLE : G55 G282
R15
Postby big_boy » Mon Dec 25, 2006 2:26 pm
thoes #`s mean nothing to me so you would have to pull out the new & old one & see if you can use bits of each to fit it all in to the new box
big_boy
Postby R15 » Mon Dec 25, 2006 2:31 pm
lovely. well thanks for your help!
hopefully i can have it running in time for work on wednsday!
(im using my van for work at the mo)
R15
Postby strx7 » Tue Dec 26, 2006 2:12 pm
R15 wrote:the auto van says TRANS / AXLE : 8E2 G142
G142 = 4.88:1 2 spider single spinner
G282 = 4.3:1 2 spider single spinner
Postby larryex » Tue Dec 26, 2006 6:45 pm
Hello R15... I have sent you a PM in regards to this topic..
Chris
larryex
