AirCon Vacum Hose & ECU Speed Sensor
Postby wjw » Fri Dec 29, 2006 2:11 pm
Been trying to find the Vacum Hose and actuator that the aircon uses to up the idle on a 2JZ-GE. Looked in the manual and on the motor but can't find it.
Anyone got any ideas?
Also does the ECU use the speed sesor input for anything other than shifting of the trans? Anyone know what sort of input it's expecting?
TIA,
Bill
1993 LandCrusier Prado, 2JZ-GE
wjw
Postby big_boy » Sat Dec 30, 2006 9:04 pm
fire wall on the late ones under the manafold on early ones
spedo as well i think
big_boy
Postby sergei » Sat Dec 30, 2006 9:11 pm
Actual SPD sensor signal does not come straight from gearbox sensors, it actually comes from Speedo unit itself (which reads the gearbox sensor).
Postby wjw » Sat Dec 30, 2006 9:39 pm
Any idea what the differences are between the two speed sensors?
Bill Walker
On the Drive: 93 LWB Prado, 3L Straight 6 (2JZ-GE)
On the Shelf: Lockers, 100mm Lift springs, Bigger Spots
Soon: 35's
wjw
